Old October 5, 2015, 05:56 PM
Default Laptop adapters: different amps matter?
I have a number of different laptops that were given to me but only a few adapters. I'm think I want to buy additional adapters w/match the specs for output voltage (19v not 18.5v), but does the amperage matter that much? Can amps be close or should it also match exactly.
Also, I see reviews where some cheap adapters crap out quickly, anyone know of quality brands for replacement adapters or what I should look for?
Thank you,
Mac
Old October 5, 2015, 07:37 PM
CTA's Avatar
CTA CTA is offline
i believe different amp will under or over stress on battery and or the electronic parts ... i dont recommend that...
recommend (average) amp is more safe choice in my point of view...
anyway.. why not buy used adapter? (or similar numbers that you can check)
Old October 5, 2015, 07:42 PM
sweenytodd's Avatar
Voltage does matter, but amperage not (make sure check the polarity sign as well). The device will only draw the power needed on the power supply.
If a light bulb needs 12V , 1 Amp. You need a 12 V , 1 Amp power supply. Using a 12 V , 2 Amp power supply will be fine as the bulb only needs 1 Amp to draw. Using a 12V , 250 mA or 0.25A power supply and you will melt the wire and bad things will happen because the PSU cannot supply enough amperage to the bulb.
Old October 5, 2015, 07:53 PM
Lpfan4ever's Avatar
Sweenytodd is right. As long as the amperage is equal to or higher than your laptop is rated for, you will be fine.
Originally Posted by encorp
Code:
<firebane> slightly used
Tags
adapters , laptop
Headphones Amps bliz Audio 4 January 18, 2013 08:49 PM
Any tuner / cd / amps out there? 3.0charlie Audio 0 May 21, 2011 07:14 PM
How many Amps for.... kruzn4evr Video Cards 6 February 20, 2010 12:14 AM
SKYMTL is this Enough Amps for 9600GT TopDogZero Power Supplies 3 June 19, 2008 05:14 AM
