Old November 20, 2016, 12:05 PM
Shadowmeph's Avatar
Default not sure how to setup my rx480
Ok been a very long time since I have done any folding I used to do CPU folding in Linux. now I installed windows version 7.4.4 and just want to test it just using my RX480 8Gb but am not sure how to just use GPU folding and of course I don't want the GPU doing full bore because I do use this system for pretty much everything. in the advanced control I noticed tha tI cannot change the cpu setting from -1 I tried to change it to 0 but when I open it up again it shows -1. do I just go to the slots and remove the cpu from there?
also whe n Iright click on the task bar the folding it shows medium is t ha tthe setting for how much of the system is being used? my gpu current temp id 67c which I am not sure if that is good or bad lol.
Old November 20, 2016, 02:08 PM
MARSTG's Avatar
You shouldn't touch the settings for the GPU, -1 it means that it will serve to your first gpu, unless you have more than one in your system. Also you should have no cpu client created, only GPU. And you should go full bore on the GPU see how it does and make sure you don't forget your passkey. Check the setup described here or on the Fah forums.
Old November 20, 2016, 06:00 PM
Shadowmeph's Avatar
in the advanced control it says 291067 points per day I am guess that is a guesstimate average
Old November 20, 2016, 06:27 PM
MARSTG's Avatar
Nice! You did it. Now keep us in the loop. What's your folding id?
Flashing RX480 from 4GB to 8GB still a thing??? Coach Video Cards 11 August 29, 2016 04:00 PM
AIB Radeon RX480 stock Tyrann Video Cards 10 August 17, 2016 08:42 AM
RX480 more powerful than GTX 980 MARSTG Video Cards 55 June 29, 2016 02:40 PM
GTX 970 Post RX480? sswilson Price Check 25 June 29, 2016 02:14 PM
RX480 up for pre order on NCIX gerardfraser Video Cards 57 June 29, 2016 01:42 PM
