Feature Testing: Mystic Light
In the introduction, we mentioned that that the X370 XPower Gaming Titanium has a rather unique LED lighting feature since it doesn't use RGB LEDs, just white ones. This is a bold choice given what while yes, white lighting does look when great paired with this motherboard, giving users the choice to select their preferred colour would have been the better option. As implemented, the lighting zones cannot be independently and there are also only five animation effects. The lack of effects is partly due to the lack of RGB LEDs, since you can't exactly pull off a rainbow effect with only white lightning.
While the white lighting looks great on this model, the aesthetic is disturbed by a number of other LEDs. You see the power and reset buttons have green lightning, the Debug LED display and a half dozen other diagnostic LEDs are of the red-only variety, and the two LEDs that indicate whether the CPU fans headers are in PWM or DC modes are either red or green. What this means that is that no matter what, you cannot really achieve a uniform colour pattern on this motherboard.
Thankfully, if you so choose, you can disable all of the white LEDs and instead use your own lighting since the onboard RGB LED header will allow you to plug in two 5050 RGB LED light strips and have them fully powered by the motherboard. You can simply attach the light strips to the included extension cable, and attach that cable to the header. This approach not only saves you money, and reduces clutter inside your system, but also gives you full control over the strips from inside the LED application.
Let's take a peek at the LED utility again:
The LED utility is obviously the piece of software in charge of controlling the Mystic Light LED lighting feature. Whether you like LED lighting or not, you will need to install this piece of software (which is integrated into the Gaming App) since there is basically no LED settings in the UEFI. If you want to disable this feature, it is as simple as clicking the icon in the top-right corner.
Using the LED utility you can customize the lighting with your choice of five lighting effects, such as breathing, flashing, double flashing, random, or you can enable the extended effects and it can react to your music or your CPU temperature. You can also choose to disable all effects, and just display a static colour. The Extend LED Effects area reveals small number of colours and additional effects that, but they don't actually apply to this particular motherboard, at least not in stock form. We suspect that they might only work when you install a LED light strip.
As you can clearly see, the overall lightning effect is not exactly brilliant or blinding since the LEDs are largely relegated to the right side of the motherboard. Some LEDs near the rear I/O area and perhaps next to the PCI-E slots would have gone a long way towards to improving the overall lighting effect. This pales in comparison to what MSI managed on their much cheaper Z270 Gaming M7, so colour us disappointed.
While there might be more LED lighting on this motherboard than on the ASRock X370 Taichi, it still pales in comparison to the GIGABYTE AX370-Gaming 5. As they demonstrated with the aforementioned MSI Z270 Gaming M7, they are capable of doing so much better than they have with the X370 XPower, and we don't understand why they held back on such an expensive motherboard.
