Quantcast
G.Skill Phoenix Blade 480GB PCI-E SSD Review
Author: AkG
Date: January 3, 2015
Product Name: Phoenix Blade
Part Number: FM-PCx8G2R4-480G
Warranty: 3 Years
Share |
Testing Methodology
Testing a drive is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes. Rather, there are factors such as read / write speed and data burst speed to take into account. There is also the SATA controller on your motherboard and how well it works with SSDs & HDDs to think about as well. For best results you really need a dedicated hardware RAID controller w/ dedicated RAM for drives to shine. Unfortunately, most people do not have the time, inclination or monetary funds to do this. For this reason our test-bed will be a more standard motherboard with no mods or high end gear added to it. This is to help replicate what you the end user’s experience will be like.
Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the Windows 7 load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being an Intel DC S3700 800GB Solid State Drive.
For synthetic tests we used a combination of the ATTO Disk Benchmark, HDTach, HD Tune, Crystal Disk Benchmark, IOMeter, AS-SSD, Anvil Storage Utilities and PCMark 7.
For real world benchmarks we timed how long a single 10GB rar file took to copy to and then from the devices. We also used 10gb of small files (from 100kb to 200MB) with a total 12,000 files in 400 subfolders.
For all testing a Asus Z97 Deluxe motherboard was used, running Windows 7 64bit Ultimate edition. All drives were tested using AHCI mode using Intel RST 10 drivers.
All tests were run 4 times and average results are represented.
In between each test suite runs (with the exception being IOMeter which was done after every run) the drives are cleaned with either HDDerase, SaniErase or OCZ SSDToolbox and then quick formatted to make sure that they were in optimum condition for the next test suite.
Processor: Core i7 4770K
Motherboard: Asus Z97 Deluxe
Memory: 8GB Corsair Vengeance LP “blue”
Graphics card: Asus 5550 passive
Hard Drive: Intel DC S3700 800GB, Intel 910 800GB
Power Supply: XFX 850
SSD FIRMWARE (unless otherwise noted):
OCZ Vertex 2 100GB
: 1.33
Intel 520: 400i
SanDisk Extreme 240GB: R211
Corsair Neutron GTX 240GB: M206
Intel 335 180GB: 335
SanDisk Extreme 2 240GB: R1311
Seagate Pro 600: B660
OCZ Vector 150 240GB: 1.2
Angelbird Adler 640GB: AA3.15
Vertex 460 240GB: 1.0
ADATA SP920 512GB: MU01
Intel 7230 240GB: L2010400
Samsung 840 Pro 256GB:DXM06B0Q
Crucial MX100 512GB: MU01
Crucial M550 512GB: MU01
Plextor M6e 256GB: 1.03
Plextor M6s 256GB: 1.03
Kingston HyperX Fury 240GB: 5.60
AMD R7 240GB: 1.0
G.Skill Phoenix 480GB: 2.71
Samsung MDX controller:
Samsung 840 Pro 256GB- Custom firmware w/ 21nm Toggle Mode NAND
SandForce SF1200 controller:
OCZ Vertex 2 - ONFi 2 NAND
SandForce SF2281 controller:
Intel 520 - Custom firmware w/ ONFi 2 NAND
Kingston HyperX Fury 240GB - Custom firmware w/ 128Gbit ONFi 3 NAND
G.Skill Phoenix 480GB - Custom firmware w/ 128Gbit ONFi 3 NAND
LAMD controller:
Corsair Neutron GTX - Toggle Mode NAND
Seagate 600 Pro - Custom firmware w/ Toggle Mode NAND
Marvell 9183 controller:
Plextor M6e 256GB- Custom firmware w/ 21nm Toggle Mode NAND
Marvell 9188 controller:
Plextor M6s - Custom firmware w/ 21nm Toggle Mode NAND
Marvell 9187 controller:
Crucial M500 - Custom firmware w/ 128Gbit ONFi 3 NAND
SanDisk Extreme 2 - Custom firmware w/ 19nm eX2 ABL NAND
Marvell 9189 controller:
ADATA SP920 - Custom firmware w/ 128Gbit ONFi 3 NAND
Crucial M550 - Custom firmware w/ 128Gbit ONFi 3 NAND
Crucial MX100 - Custom firmware w/ 128Gbit ONFi 3 NAND
Barefoot 3 controller:
OCZ Vector 150 (M00) - 19nm Toggle Mode NAND
AMD R7 (M00) - 19nm Toggle Mode NAND
Novachips NVS3600A controller:
Angelbird Adler - ONFi 2 NAND
Intel X25 G3 controller:
Intel 730 - Custom firmware w/ ONFi 2 NAND
Steady-State Testing for Workstation Environments
While optimum condition performance is important, knowing exactly how a given device will perform after days, weeks and even months of usage is actually more important for most consumers. For home user and workstation consumers our Non-Trim performance test is more than good enough. Sadly it is not up to par for Enterprise Solid State Storage devices and these most demanding of consumers.
Enterprise administrators are more concerned with the realistic long term performance of any device rather than the brand new performance as down time for TCL is simply not an option. Even though an Enterprise device will have many techniques for obfuscating and alleviating a degraded state (eg Idle Time Garbage Collection, multiple controllers, etc) there does come a point where these techniques fail to counteract the negative results of long term usage in an obviously non-TRIM environment. The point at which the performance falls and then plateaus at a lower performance level is known as the “steady state” performance or as “degraded state” in the consumer arena.
To help all consumer gain a better understanding of how much performance degradation there is between “optimal” and “steady state” we have included not only optimal results but have rerun tests after first degrading a drive until it plateaus and reaches its steady state performance level. These tests are labelled as “Steady State” results and can be considered as such.
While the standard for steady state testing is actually 8 hours we feel this is not quiet pessimistic enough and have extended the pre-test run to a full ten hours before testing actually commences. The pre-test or “torture test” consists of our standard “NonTrim performance test” and as such to quickly induce a steady state we ran ten hours of IOMeter set to 100% random, 100% write, 4k size chunks of data at a 64 queue depth across the entire array’s capacity. At the end of this test, the IOMeter file is deleted and the device was then tested using a given test sections’ unique configuration.
Primary Hard Drive: Intel 520 240GB
Below is a description of each SSD configuration we tested for this review:
Intel 910 800GB (Single Drive) HP mode: A single LUN of the Intel 910 800GB in its High Performance Mode
Intel 910 800GB (Raid 0 x2) std mode: Two of the Intel 910 800GB SSD LUN's in Standard Mode Configured in RAID 0
Intel 910 800GB (Raid 0 x2) HP mode: Two of the Intel 910 800GB SSD LUN's in High Performance Mode Configured in RAID 0
Intel 910 800GB (Raid 0 x4) std mode: All four of the Intel 910 800GB SSD LUN's in Standard Mode Configured in RAID 0
Intel 910 800GB (Raid 0 x4) HP mode: All four of the Intel 910 800GB SSD LUN's in High Performance Mode Configured in RAID 0
Intel DC S3700 200GB: A single DC S3700 200GB drive
Intel DC S3700 800GB: A single DC S3700 800GB drive
Intel DC S3700 200GB (RAID 0): Two DC S3700 200GB drives Configured in RAID 0
Intel DC S3700 800GB (RAID 0): Two DC S3700 800GB drives Configured in RAID 0
Intel 710 200GB (RAID 0): Two 710 200GB drives Configured in RAID 0
Latest Reviews in Storage
March 6, 2018
The Crucial MX500 follows in the footsteps of some of the best SSDs; the MX300 and MX200. But in a very competitive market, can it even compete these days?...
February 25, 2018
It is the FASTEST SSD we've ever tested, providing unbelievable benchmark performance but the Intel Optane SSD 900P also has some very serious limitations....
January 9, 2018
Toshiba has announced the new RC100 NVMe M.2 SSD Series, which targets value-oriented gamers, DIY system builders, and system integrators....
