Quantcast
Intel i7-4930K & i7-4820K Ivy Bridge-E Review
Author: SKYMTL
Date: September 10, 2013
Product Name: i7-4930K / i7-4820K
Part Number: BX80633i74820K / BX80633i74930K
Warranty: 3 Years
Share |
Test Setups & Methodology
For this review, we have prepared a number of different test setups, representing many of the popular platforms at the moment. As much as possible, the test setups feature identical components, memory timings, drivers, etc. Aside from manually selecting memory frequencies and timings, every option in the BIOS was at its default setting.
For all of the benchmarks, appropriate lengths are taken to ensure an equal comparison through methodical setup, installation, and testing. The following outlines our testing methodology:
A) Windows is installed using a full format.
B) Chipset drivers and accessory hardware drivers (audio, network, GPU) are installed.
C)To ensure consistent results, a few tweaks are applied to Windows 7 and the NVIDIA control panel:
  • UAC Disabled
  • Indexing Disabled
  • Superfetch Disabled
  • System Protection/Restore Disabled
  • Problem & Error Reporting Disabled
  • Remote Desktop/Assistance - Disabled
  • Windows Security Center Alerts Disabled
  • Windows Defender Disabled
  • Screensaver Disabled
  • Power Plan High Performance
  • V-Sync Off
D) Windows updates are then completed installing all available updates
E) All programs are installed and then updated.
F) Benchmarks are each run three to eight times, and unless otherwise stated, the results are then averaged.
G) All processors had their energy saving options / c-states enabled
Latest Reviews in Processors
November 12, 2018
Intel's i9-9980XE is an expensive flagship processor but it isn't anything new either. This CPU is basically a higher clocked version of the i9-7980XE and Intel may have some challenges maintaining a...
October 18, 2018
With the launch of this 9th generation Core processor family, Intel have finally caught up to AMD in the mainstream processor core war....
August 12, 2018
AMD's second generation Threadripper processor are finally here with the 2950X, a CPU that promises better performance than the 1950X and Intel's 7900X but for less money....
