Quantcast
ASUS Radeon HD 5870 1GB V2 Review
Author: Michael "SKYMTL" Hoenig
Date: May 9, 2010
Product Name: ASUS Radeon HD 5870 1GB V2
Share |
Focusing on DX11
It has been a hair under three years since the release of Windows Vista and with it the DirectX 10 API. In that amount of time, a mere 33 DX10 games were released. That isnít exactly a resounding success considering the hundreds of titles released in that same time. Letís hope DX11 does a bit better than that.
DX11 is focused on taking the lessons learned from the somewhat inefficient DX10 and shaping them into a much more efficient API which will demand less system resources while being easier to develop for. In addition to the usual 3D acceleration, it will also be used to speed up other applications which in the past have not been associated with the DirectX runtime. This may be a tall order but with the features we will be discussing here, developers have already started using DX11 to expand the PC gaming experience. It is an integral component in Windows 7 and according to Microsoft, will also be adopted into Windows Vista through a software update.
Letís scratch the surface of what DX11 can bring to the table.
Unlike past DirectX versions, DX11 endeavours to move past the purely graphics-based uses of the API and push it towards being the lynchpin of an entire processing ecosystem. This all begins with the power which DirectX Compute will bring into the fold. Not only can it increase the efficiency of physics processing and in-game NPC intelligence within games by transferring those operations to the GPU but it can also be used to accelerate non-3D applications.
Through the use of Compute Shader programs in Shader Model 5.0, developers are able to use additional graphical features such as order independent transparency, ray tracing, and advanced post-processing effects. This should add a new depth of realism to tomorrowís games and as mentioned before, also allow for programs requiring parallel processing to be accelerated on the GPU.
For the majority of you reading this review, it is the advances in graphics processing and quality that will interest you the most. As games move slowly towards photo-realistic rendering quality, new technologies must be developed in order to improve efficiency while adding new effects.
Some of the technologies that ATI is championing are DX11ís new Depth of Field, OIT (or Order Independent Transparency) and Detail Tessellation. While the pictures above do a good job of showing you how each of these works, it is tessellation which ATI seems most excited about. They have been including hardware tessellation units in their GPUs for years now and finally with the dawn of DX11 will these units be finally put to their full use. OIT on the other hand allows for true transparency to be added to an object in a way that will be more efficient resource-wise than the standard alpha blending method currently used.
Letís talk about DX11 games. As you would expect, due to the ease of programming for this new API and the advanced tools it gives developers, many studios have been quite vocal in their support. Even though some of the titles listed above may not be high on your list of must have games, A-list titles like Aliens vs. Predator from Rebellion, DiRT 2 and Battlefield: Bad Company 2 have people interested already and there are more to come.
Latest Reviews in Video Cards
November 15, 2018
The AMD Radeon RX590 is a "new" GPU that's based on old technology. But our performance benchmarks may tell a different story when the RX590 is compared against the RX580 and GTX 1060 6GB....
October 15, 2018
The RTX 2070 launch is upon us and this time we have the $500 ASUS RTX 2070 Turbo and $550 EVGA RTX 2080 XC to check out....
September 18, 2018
The NVIDIA RTX 2080 and RTX 2080 Ti's promise to be two of the fastest graphics cards ever produced. Let's see if our suite of performance benchmarks backs up that claim....
