Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old August 12, 2018, 08:47 PM
Question 2 GPU's w/o SLI?
In the 2950X build video, Eber mentioned using 2 1080Ti's to do 2 separate tasks. How is that setup exactly and would it work with an AMD/Nvidia combo as well?
https://youtu.be/3SXGFaKImw4?t=355
Old August 13, 2018, 07:59 AM
FreeKnight's Avatar
As far as disabling SLI, if I remember correctly, when you've got two cards plugged in, just go to the Nvidia control panel (right click on the desktop background and it should be an option), and under 3D settings there should be an SLI config tab. In there you can disable SLI. Should work on an AMD/Nvidia combo as well as a Intel/Nvidia as it's directed by the GPU settings/driver.
Old August 13, 2018, 11:54 AM
Running 2 Nvidia cards will not automatically put it into sli mode
With that said what are you doing that you want to do this?
Old August 13, 2018, 12:20 PM
Editing and gaming. I asked about an AMD/Nvidia combo because DaVinci Resolve works best with an AMD card while Nvidia cards generally perform better for everything else.
Old August 13, 2018, 01:55 PM
MARSTG's Avatar
They would work fine together , i have a 290X and a 1070Ti and there is no conflict .
Old August 18, 2018, 10:43 PM
Shadowarez's Avatar
Is that lucid logic software still being developed?
Beast
CPU - i9 7980xe 4.6ghz
Mobo - Rog Asus Apex x299
Ram - 32 GB Corsair 3200mhz 4x8GB
GPU - Vega FE 1650 Core 1080 HBM 2 (1090MV)
Case Corsair 1000D
Storage
1.intel 900p 280gb Optane U.2/M.2 (Os)
2.intel 750 1.2TB (steam)
3.intel 910 Pcie Ssd 800gb (Work/Scratch)
4.WD Black SN750 3x1TB NVME m.2(future)
Old August 20, 2018, 01:04 PM
MARSTG's Avatar
No, is dead, has been replaced by DX12 EMA ( Explicit Multi Adapter )
https://www.google.ca/search?q=dx12+...hrome&ie=UTF-8
Old August 21, 2018, 11:38 PM
Shadowarez's Avatar
Nice now just wait for Devs to implement it seen GTA 5 with 24 GB of vram was nice lol even though I know it can't use it lol
Beast
Case Corsair 1000D
Storage
