Old October 24, 2015, 02:35 PM
Default 1440p 144hz IPS Monitor Help!
I am looking for a 1440p 144hz IPS monitor but I don't know which one to get. Either should I get the Asus pg279q now or wait till the price drop? I live in UK so it cost 700. What do you guys think?
Old October 24, 2015, 03:09 PM
lowfat's Avatar
It is brand spanking new. People just started getting them like a week ago. You won't see a price drop for a very long time. There are ZERO others worth buying IMO.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old October 24, 2015, 03:58 PM
CTA's Avatar
CTA CTA is offline
what about "Asus MG279Q" it has also ips and 144hz...
Old October 24, 2015, 05:09 PM
The thing its freesync. I have nvidia gtx 980 ti. So yh
Old October 24, 2015, 05:11 PM
Well is it worth getting the ASUS ROG PG278Q TN than the pg279q ips? Or what?
Old October 24, 2015, 08:17 PM
lowfat's Avatar
I've had the PG278Q for close to a year and like it a lot. Best display I've owned personally, and I've owned quite a few. It is a 10-bit panel so colours are better than any other TN out there. It also doesn't suffer from IPS glow unlike the new panel. My panel is pretty much flawless and AFAIK most of the newer 278Qs have relatively good quality control. If gaming is your primary usage I personally think it is a great choice. I've put probably a thousand hours of gaming on mine this year and never once have I said "I wish this had better colours" .
Queen of Dreams WIP
Big Lian Li
Complete
Old October 25, 2015, 09:41 AM
The reviews are just coming down for the PG279Q. Seems positive so far but QC is yet again going to be a problem. People are reporting IPS bleed , stuck/dead pixels while others are getting perfect monitors. Also 165hz is fine and all but unless you have a GTX 980 (ti) Titan or the Higher end AMD card you can forget about ever hitting that . I've been considering this monitor ever since it was unveiled at CES but with a GTX 780 I don't think I could even touch anything pass 100 hz.
Gaming Rig
Core i7 7700k 4.7ghz
EVGA RTX 2080ti XC 11GB GDDR6
Asus PG348Q + Dell U3415W
Asus Z270 Prime
16GB DDR4 Corsair Vengeance 3200 mhz
Samsung 850 Pro 500gb
Crucial MX500 1TB
Crucial MC300 500GB x2
Corsair RM750i
Corsair Obsidian 750D
Razer Deathadder Chroma 2018
Logitech G710 +
Asus Xonar Essence STX
Sennheisers PC360
Audioengine A2+ Speakers
Old October 25, 2015, 10:18 AM
You need a Maxwell Gen 2 card (960 and above, so possibly not 950) to achieve 165hz on the monitor. It's a limitation to how the monitor is overclocked to achieve 165hz.
That being said, I sincerely doubt the difference between 144hz and 165hz is perceivable - it's just not a big enough jump. It's mostly a marketing stunt to trumpet over the Acer models - XB270HU and upcoming "refresh" XB271HU
Old October 25, 2015, 10:51 AM
Yea but is a 960 going to run GTA V or BF4 at ultra or even high settings with decent FPS on a 2560X1440 monitor ?
Gaming Rig
Asus Z270 Prime
Crucial MX500 1TB
Corsair RM750i
Logitech G710 +
Sennheisers PC360
Old October 25, 2015, 11:06 AM
My point was that you can not achieve 165hz on the monitor unless you have the appropriate Maxwell cards. Even if you were running Tri-SLI with 780s you would never get 165hz on this monitor. As soon as you enable it, the monitor would display 120hz.
[FS] Sold YukonTrooper Buy/Sell & Trade 4 April 25, 2017 04:39 PM
[WTB] 27" 1440p Monitor Kindred1 Buy/Sell & Trade 10 March 16, 2015 09:08 PM
Wanting to buy my first 1440p IPS monitor. dtnat Display Units 10 February 26, 2015 11:11 AM
[FS] Asus VG278HE 144hz Monitor with Lightboost' Squeetard Buy/Sell & Trade 4 November 11, 2014 03:19 PM
Price check on 144hz monitor and GTX580 Bao Price Check 0 September 10, 2013 07:52 AM
