Old March 11, 2019, 04:38 PM
Default When to replace hardware?
Hello HWCs!
In my original post about my mobo failing https://www.hardwarecanucks.com/foru...placement.html
I figured out that it was the mobo giving me trouble. I don't want to buy a new mobo for a old 2011 platform.
I would rather scrap it / reuse the parts for another system or sell it off.
The mobo was a second hand mobo though and was used heavily over the past 8 years of use.
I have a question about long term use about my other old 2011 system that I use as a server (My system specs).
That computer is a server/HTPC. Should I think of retiring 5+ year hardware? I would rather have a usable system than run it till it dies...
I am thinking of getting the older but capable AMD Ryzen 1700 from MikesCS and get a B350 mobo to run as my server lol. And retire my current server/HTPC so it can still be used time to time.
I hate it that my ASUS mobo died.... I thought it would last at least 12 years... but it was an ITX H61 version 2.0 board... and used.
Laptop: Dell 15 5005U, 8GB, EVO860 500GB+QVO860 1TB, Microsoft Sculpt Comfort Mouse BT
HTPC/Server: See "My System Specs". I also use it to virtualize instances of Windows 7/10 to my mobile devices. Fast access to all my Chrome tabs :lol:
Graphics Designer and Tech Journalist @ www.RealHardwareReviews.com ID: eyetrance/Dave
Personal Website @ www.EYEtrance.ca
Old March 11, 2019, 04:42 PM
What system do you have that is 2011? I'm still running x79 without issue but a board replacement is definitely not worth it.
If it's the 2600k that is 1155 and should be able to find a fairly cheap board.
Old March 11, 2019, 04:50 PM
YEar 2011 Sandybridge era.
Fairly Cheap board are all used mostly though but how long will it last? I would rather get my self a good AMD B350 board new for like $70 or buy two because the AMD 1700 I hope to buy will outlast everything plus ram.
I finally have a full time job right now and scared of my HTPC computer (not in my sig but with an i7 3770 in the dropdown button system specs will die soon because I run it 24/7
Old March 11, 2019, 07:30 PM
JD JD is offline
5 years is a pretty normal life cycle for a computer, that's what a lot of businesses run with. I wouldn't say there's any exact time frame though, things will die "randomly". I'd say it's a bit better to spend a little extra when buying to get something a little higher quality as the chances are it will last longer.
The system in your specs should keep running a while longer I'd say... I have a 2500k and P8P67 PRO still going fine.
I think I have a P8H61-I (could be H67 version) here that has weird boot problems (maybe similar to what you had) which I was running as a HTPC until I moved to Android TV. It's been like that for over a year now though. Actually, maybe the H61 died and I threw it out...can't remember...
Old March 12, 2019, 05:34 AM
Lysrin's Avatar
Life cycling certainly makes sense, as JD said, in a fixed time frame, IMO dependent on how critical the system is. At work we of course life cycle the big important stuff based on a number of factors: performance, warranty coverage, etc. That makes good sense if a system going down is going to result in cost or extended downtime.
For a home system, I guess I'd base my decision on how critical the system is and how available my funds are! ;) At home, as long as your stuff is backed up, the system going down is likely less of a risk, more of an inconvenience. And how long things run is really hard to guess. I have a i7 920 system that is still running strong, taking on some small server roles eventually, but runs no different today than when I first put it together! They were launched in late 2008 and I bought shortly after launch. Still same motherboard as with original purchase. It could die the next time I turn it on, but I'll likely keep using it until it does.
i7 8700K @ 4.8GHz (Swiftech H220) | ASUS Maximus X Code | 32GB Corsair Vengeance RGB Pro DDR4-3200 | ASUS ROG GTX 1080 Ti Strix OC ver. | EX920 512GB, MX100 512GB, MX300 2TB | EVGA Supernova 850W G2 | Meshify C | Mayflower Electronics O2+ODAC, USB sound for mic, Sennheiser PC360 SE | Acer Predator X34, BenQ 21.5" | Windows 10 Pro
Old March 12, 2019, 07:44 AM
My inlaws used their past comptuer for about 10 years with me cleaning it occasionally but it was a glorified web browser. I replaced it with an APU based system and I'd expect it to last another 10 before they consider doing anything with it.
Personally my last motherboard was a Crosshair 4 Extreme from 2010 but it went through 3 different CPU's, don't recall what I bought it with but then it had an 1100T and a FX-8XXX series CPU in it but 32GB ram that whole time. It probably went through a dozen combinations of video cards though (some borrowed for testing).
2700X Heatkiller, CH7 Hero, 1080ti Heatkiller, 32GB Ram, 2x500GB WD Black NVMe, Dual 1080 rads, dual D5S pumps.
Old March 12, 2019, 08:22 AM
Lysrin's Avatar
That support from AMD for multiple processors for the same socket has always been a plus in my mind. Certainly helps with longevity of systems for the money you invest!
Old March 12, 2019, 12:15 PM
Bond007's Avatar
If it has critical data, make sure its backed up...everything else nearly irrelevant as long as if something died that you can afford a little bit of down time. If the PC is doing what you want it to and the data as backed up, then run it until either: 1) it isn't doing what you want anymore 2) it fails 3) the urge to upgrade can't be contained anymore
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old March 12, 2019, 12:25 PM
Entz's Avatar
I keep saying I will replace my 3930k rig once it dies, but I am pretty sure at this point it will keep working forever just to spite me.
Old March 13, 2019, 05:09 AM
nToxik's Avatar
Still using my 2600K, 8GB RAM but planning a new Zen2 build this summer/fall.
Want to replace my 360 rad clshades Water Cooling 11 February 26, 2012 06:47 PM
Fix or replace my receiver? Agafaba Audio 10 October 19, 2011 09:15 PM
Replace HDD? Hunt Storage 11 February 15, 2010 12:33 PM
Some new parts, to replace old ones AmuseMe New Builds 9 July 6, 2009 01:45 PM
