Old January 20, 2011, 08:43 PM
Default Gigabyte GA-880GMA-UD2H- crossfire
does anyone know if this board would support a low profile dual GPU crossfire setup?
it has 2 pcie 16 slots(one 16x one 4x) so it may seem like a dumb question but gigabyte makes no reference to dual gpu crossfire on the site nor can i find any reviews whee they crossfired it.
also if you notice the pcei 16 slots are really close together which would be a problem i dont think with low pro cards however im starting to thin this board doesn't allow 2 gpu's
GIGABYTE - Motherboard - Socket AM3 - GA-880GMA-UD2H (rev. 2.2)
Old January 20, 2011, 08:59 PM
spikexp's Avatar
It will support crossfire, but it would be to hard to find single slot video card to crossfire. I don't think crossfire require anything special except from having 2 physical PCI-E16X.
And unlike what many people say about crossfire/sli, 16x/16x, 8x/8x, 16x/4x, hell even 4x/4x
the difference in performance is of the order of 5%, 1FPS in most game with gtx 480, so you don't need to care about this (you didn't ask, but it's important to say it).
Old January 20, 2011, 09:52 PM
DkRk's Avatar
XFX has a single-slot 5770 that will fit the bill.
Protect your chicken from Dokken.
Old January 20, 2011, 10:32 PM
spikexp's Avatar
... Yeah, but still the card would be really close, they would have difficulty to breathe. Probably hard to find crossfire bridge that small (unless they are flexible?) xD
I think it would be better to buy 1 good card than 2 small 5770.
Old January 20, 2011, 11:34 PM
nice, i didnlt know that
Old January 21, 2011, 04:44 AM
or do the driver thing and stick 2 nv's on the cheap there? gonna be loud though.
the 4x slot wil lslow you down a bit, not enough to ruin your fun! :)
Old January 21, 2011, 09:02 AM
nv's? i was thinking possibly 2 5570's but now that i know there's a low profile 5770 i might go that route when the time come if i can actually find one because it seems impossible to find
on top of that i'm still not convinced this board can run dual gpu's because it says nothing of such on he gig site, on best direct where i was going to purchase, cant find one on the net using both slots ect. Such a pain in the ass that there is only like 3 possible choices for an am3 matx with 2 pcei16, one of them is too expensive, ones a jetway, and one is this gigabyte with no notification that it runs or does not run multi gpu's
really suprised that there isn't more choice out there in terms of matx /low profile gaming. everything's been getting smaller over the years except gaming pc's
Old January 21, 2011, 09:06 AM
If that's what you want, you have no choice but to go Intel. AMD offerings are either crappy or nonexistent, due to the lack of competition from AMD. I faced a similar dilemma a while back when I was building my SFF folding/gaming rig.
nvidia cards, but theres nothing much thats that skinny and interesting, maybe a 450 or 460...
if both are connected to the same controller yup. if not, performance could suffer, i hear :)
Old January 21, 2011, 09:27 AM
yeah it sucks, made a post a year ago looking for a matx crossfire am3 board and at that time there was only one(jetway).
I've also noticed that intel has them. I'm not apposed to going intel per say but i am apposed to paying 150+ for an i-5 when i'll have a perfect good 550 to use when i upgrade my main rig(or go the athlon x3 route).
this gigabyte looks decent enough if it crossfires(4x4 crossfire doesn't brother me) but im not convinced that it does and dont want to spend an extra 50 bucks on a board if i'm goning to have a useless 2nd pcei slot(woudn't even be able to use a revo on it because i want a low profile build)
Will this work with a 880GMA Blu Peripherals 0 December 31, 2010 01:59 AM
GA-MA785GMT-UD2H is it ok for Win7 virtualization? snowbound New Builds 4 January 28, 2010 07:25 PM
Gigabyte Launches GA-X58A-UD7 with USB 3.0, SATAIII and SLI/Crossfire FiXT Press Releases & Tech News 7 December 7, 2009 01:55 AM
Athlon II x4 620 + GA-MA785GMT-UD2H + ? somecanadianguy Overclocking, Tweaking and Benchmarking 8 November 5, 2009 07:58 AM
