Old September 26, 2008, 06:11 PM
Dar_ell's Avatar
Default Bios problems.
Hey everyone, been enjoying my PC for a while so i thought i might do some OC. I tried it out and got to 3.2 fine but when i got to 3.4 it got unstable (this is with stock by the way). After getting the OCZ vendetta 2 ( I HATE PUSHPINS...) installed i thought i could try it again. everything seemed fine, but when i checked cpuz it said it was on stock settings (im using the bios not that weird easy tune thing gigabyte gives you). So i tried easy tune and it worked, its just i wish i could use my bios and not rely on a program. Also since i developed a deep hatred of anything that has to do with push pins, can this back plate work with my HS? NCIX.com - Buy Thermalright LGA775 BOLT-THRU Kit for for Ultra 90/120 & HR-01 Retail Box - BTK-LGA775R In Canada.
ps. should i be worried if my 8400 was clocked 2.8ghz when i bought it? thanks HWC community.
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old September 27, 2008, 04:26 PM
Dar_ell's Avatar
so im guessing no one knows?
Old September 27, 2008, 04:43 PM
3.0charlie's Avatar
Couple of answers here:
1. you have to learn about your board (the DS3L is a very good board BTW) and how to OC. While running on stock settings, you will hit a stability wall. And changing HSF (to the Vendetta) will not make a difference. You have to use the voltage settings for stability.
2. If CPU is showing stock settings, the oc was unstable and the board booted using default settings.
3. Easytune works since it adjusts the voltages when the FSB is raised.
4. I don't know if the Thermalright back plate will work with the Vendetta.
5. Your CPU was showing a speed of 2.8 because of your BIOS settings, not because it was shipped at 2.8GHz.
Hydro-Quebec is salivating...
Old September 27, 2008, 05:08 PM
Dwayne's Avatar
I used the same kit on my OCZ Vendetta 2, you can see the worklog here on HWC:
http://www.hardwarecanucks.com/forum...detta-2-a.html
I also modded my Antec 900 at the same time, but you can see the pics of the bolt through kit and my comments. Works fine for me!
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Samsung - 960 EVO NVMe 500 GB Boot : Muskin 1 TB Reactor SATA : Crucial MX 500 1 TB SATA m.2 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA RTX 2080 XC Ultra Gaming
HTPC - MSI B360-M Gaming Plus : i3 8100 : 8 GB G Skill Ripjaws V Series: EVGA 500W 80plus : EVGA GTX 1050 SC : NMedia HTPC Case: Adata 240 GB SSD Boot
Tablet - Asus Surface clone
Wife's Rig - MSI GL72M 7RDX
