Old May 11, 2019, 07:13 PM
The Great Gazoo's Avatar
Default 10+ channel fan controller
So, I have 10 fans in my 800D case. I'm currently running them daisy chained into the 4 channels my mobo has. I'm looking ahead to my next rebuild where I will also have a very large case so I can water cool again. So, I am looking for a PWM fan controller that can handle at least 10 fans and maybe up to 12 when I get my next case (likely 1000D). I'd like to be able to control each fan on CPU temps so a UI of some sort is needed rather than just buttons or dials.
Any suggestions for me?
Old May 11, 2019, 08:06 PM
Looks like 10 is the max number of ports I can find on Amazon.
Old May 11, 2019, 08:27 PM
supaflyx3's Avatar
Use the commander pro that comes with the case & a second one giving you a total of 12 controllable fans
Old May 11, 2019, 09:00 PM
Bartacus's Avatar
I spent $20 on a used 6 channel fan controller, 30W per channel, if you don't mind a 5.25 bay device. Combine that with 3-to-1 splitters, and I run 3 fans per channel. Another option, IF you have PWM fans, is to get a few SATA-powered PWM hubs. I have a few of those, they run 8 fans each and cost less than $20, but can't be daisy chained. But you could run one hub off your CPU header and another off the CPU_OPT header, and control up to 16 fans with PWM.
Old May 11, 2019, 09:25 PM
rjbarker's Avatar
cannel
Yeah I agree.....been running 16 Fans in my Custom Loop (900D) off a Lamptron 4 Channel 50W / Channel Controller for 5 yrs......I really like controlling my Fans manually (not relying on Software).....a few splitters and 4 Fans per Channel.....
....The only thing plugged into any of my MOBO Headers is my pump....and a couple of RGB's....
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old May 13, 2019, 02:07 AM
dustin1706's Avatar
Do you need independent control of each fan? If not, or if you're good with control of groups of fans, you can:
-Use a couple of powered fan splitters like the Swiftech 8-way PWM splitter.
-Use a couple of passive splitters to distribute the load between 3-4 Mobo fan headers. Your mobo may or may not allow for independent control of each header. (# headers required depends on the amp draw of your fans and rating of your headers).
-Use a couple of passive splitters, but provide the power from a fan controller to take that load off of your mobo.
I researched these types of products a ton before building my current dual loop system in January and went with a bit more of an extreme route. 18 fans split into 5 zones (2x case, GPU rads - only 2x fans spinning at idle, GPU rads - remaining 6x fans at load, CPU rads - only 2x fans spinning at idle, CPU rads - remaining 6x fans at load) and 2x D5 pumps and wanted independent control of all 7 "groups" to optimize performance/noise. I ended up going with an Aquaero 6LT + Aquaero Quadro + passive splitters and it works great! There's no kill like overkill.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old May 18, 2019, 05:28 AM
Shadowarez's Avatar
Default 10 port pwm fan sata power controller
Iv bought 3 of these since my rig is a monster I have 2 commanders and 1 of these.
Haven pwm
Beast
CPU - i9 7980xe 4.6ghz 1.15v
Cooler - Noctua NH - U12A
Mobo - Rog Asus Apex x299
Ram - 64 GB Corsair Vengeance LPX 3200mhz 4x16GB
GPU - Vega FE 1650 Core 1080 HBM 2 (1120MV)
Case Corsair 1000D
Storage
1.intel 905p 380GB M.2 (Os)
2.intel 900p 280 (Ark)
3.intel 800p 118gb (HDD Cache)
3.WD 6TB Black 256mb (Bulk)
4.intel 750 1.2TB (steam)
5.intel 750 400gb
4-Channel Fan Controller w/ Multiple Fans Per Channel JoeOnePack Air Cooling 7 June 15, 2012 05:38 PM
Running Triple Channel on a Dual Channel Server Soullessone21 RAM 2 May 8, 2012 03:05 PM
Solved: Single-channel instead of Dual-Channel WesByNorthWest Troubleshooting 10 September 24, 2011 08:19 AM
Dual Channel 8GB or Triple Channel 6GB? devilwarier9 RAM 6 November 25, 2010 03:31 PM
clarification on 3 channel and Dual channel dante1 RAM 4 January 15, 2010 09:22 PM
