  #51 (permalink)
Old January 13, 2019, 09:01 PM
JD JD is offline
I had a brand new package of Gelid GC Extreme in my cupboard that I just put on my GPU. It still seemed fluid enough...probably been in there for a while though...
My tube of Thermal Grizzly was really dry though, thus I didn't want to use that. The EK Ecotherm stuff was still fine that I used originally, but figured I'd try something else.
  #52 (permalink)
Old January 13, 2019, 09:41 PM
rjbarker's Avatar
Originally Posted by clshades View Post
Moore's 10% discount cards. Perfect amount of flex.
I recall you mentioning "expired" Gift Cards ....kinda like using your Credit Card to scrape frost off the windshield .......
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
  #53 (permalink)
Old January 16, 2019, 04:24 AM
KaptCrunch's Avatar
Default j/k on peanut butter
Originally Posted by Dark Knight View Post
Better to use the included spreading spatulas as per the manufacturers suggestion if someone wants to spread (although it won't make much of a temperature difference).
Don't get the joke in that. Regardless spreading is unnecessary and introduces extra work and potential for air bubbles.
Hmmm very confusion, guess smooth peanut butter is better for easy to spread with a used spreading spatulas
  #54 (permalink)
Old January 16, 2019, 08:02 AM
Mr. Friendly's Avatar
so you just put down your rice size gob and mount the HSF?
  #55 (permalink)
Old January 16, 2019, 10:24 AM
KaptCrunch's Avatar
those imaginary micro bubble help spread the media but air huge pockets aren't good = poor coverage
roll the dough as placing heat sink one side then fold down to meet the CPU then twist back/forth a line mount clamp it down is my method
  #56 (permalink)
Old March 17, 2019, 07:10 AM
I ran out of AS5 last year, and haven't replaced it yet lol. But I am using Chill Factor 3, it came with my Thermalright coolers. I just put a blob a little bigger than a grain of rice down on the center, slap the cooler down on it, and give it a titty twister before I give it the clamps. Works good! Last night I scraped the goop off of my GTX980, and replaced with CF3, and saw about a 2-5c drop in temps, not huge, but when the load is off temps drop a lot quicker.
3770K @ 4400 1.215v/True Spirit 140 Power/TY-143 Push/Pull|x5690 E.S. @ Stock+Turbo/Le Grand Macho RT
Asus P8Z77-V/Crucial M4 256GB|Asus Rampage III Formula/Intel 520 120GB
12GB G.Skill TridentX+RipJawsX @ 900 9-9-9-24 1T 1.6v|10GB G.Skill PerfectStorm+OCZ Reaper @ 666 6-8-6-24 1T 1.6v
EVGA GTX 980 Classified 3988 @ 1417/1753|EVGA GTX 970 FTW ACX 2.0 @ 1404/1753
Fractal Design Meshify C TG/CM Silent Pro M2 850|Fractal Design Define R4/TT SPM850
