Old April 9, 2018, 11:08 AM
Lysrin's Avatar
Still running a 212 Evo in my daughter's PC. It still does the job, no problem!
Old April 13, 2018, 07:12 AM
Soultribunal's Avatar
Originally Posted by sswilson View Post
Heh... my how times have changed....
Back in the early days of AIO coolers they couldn't match even a budget air cooler like the 212+........
AIO's now are my go to for cooling needs. They also help mitigate the issue I've had in the past of Heatsinks resting on or not fitting near all the cooling fins of everything else (power phase, RAM).
They have come a long way.
Air Coolers though, will last the test of time. My TT Down Draft cooler is on 5 years now, still works fine.
-ST
www.realhardwarereviews.com
Old April 13, 2018, 09:40 AM
nToxik's Avatar
Also still running my 212 Evo with dual push/pull Noctua fans on my 2600K which I installed back in 2011.
Old April 13, 2018, 10:02 AM
Shadowmeph's Avatar
when I bought a used AMD Phenom II X6 just after they came out I had a air cooler on it two fans wasn't a expensive one, anyway I had that system for about 3 years then sold it to my Nephew who still is using that system with the same cooler . when I switched out systems that was way back just after the New CPUs came out after the Intel 2500k so this goes to show you how long at least in my case they last
Old April 14, 2018, 08:36 AM
Dark Knight
Guest
Posts: n/a
Unless you are running on stock the 212 Evo is not a significant improvement over the stock cooler. Plus seeing as it's a Coolermaster Design their installation and mounting methods aren't user friendly and time consuming compared to a Noctua.
Old April 14, 2018, 02:25 PM
I have a really old OCZ 92mm Vendetta tower cooler using an AM3 clip to mount to a circle plastic bracket on a Intel Socket 1155. Easy design. Temps good too on stock i7 3770 below 60.
Gone mobile and back to Gaming to LEARN! :p
Laptop: Dell G5 i5-8300H, 16GB, 1050 4GB, Samsung EVO 970 500GB+EVO 860 500GB, Microsoft Sculpt Comfort Mouse
Gaming PC: i7-2600K, 24GB, EVGA 1070 8GB, Crucial BX500 250GB, WD 4TB, ASUS Xonar DX playing just CS:GO and some StarCraft 2
HTPC/Server: See "My System Specs". I also use it to virtualize an instance of Windows to my mobile devices.
Graphics Designer and Tech Journalist @ www.RealHardwareReviews.com ID: eyetrance
New life Kallapz New Builds 8 April 18, 2015 07:39 AM
Life? James Bond 007 Storage 4 January 8, 2012 04:55 PM
Cpu life Luther CPU's and Motherboards 8 December 15, 2011 01:34 AM
For those who take life too seriously jay51 Off Topic 4 September 18, 2010 08:10 AM
Windows XP has a bit more life enaberif Press Releases & Tech News 49 June 23, 2009 10:55 PM
