Old May 5, 2008, 05:31 PM
Default Thermolab Micro Silencer
[Frostytech.com] "As you can see, this cooler was outperformed by the other heatsinks, except for the Nano Silencer, in each test. When you take a look at the size difference between the Micro Silencer and the other heatsinks it was compared to, it should not have been able to beat them or even come close. However, again taking a look at its size, it is able to remove the heat off of the processor better than the stock cooler provided by Intel."
More...
