  #21 (permalink)
Old September 9, 2008, 06:35 PM
Jackquelegs's Avatar
ME WANTEE!
Iapetos
Zephyranthes
  #22 (permalink)
Old September 9, 2008, 06:41 PM
Cptn Vortex's Avatar
I dunno, it wasnt spectacular.... I think the setup you listed 3.0 would be much better, and have much more headroom to grow. Change that PA120 out for a MCR320 and save a lot of extra cash, and only use 3 fans....
I see this being a better choice for someone who doesnt want to mess around with building and installing and risking building they're own setup, but no its not for me.
The Vortex H20
EVGA SR-2 Classified
2 x Xeon L5639 Hexcore CPUs, 3.2GHZ
EVGA GTX 580 - 940/2115
24GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 90GB Corsair Force SSD RAID0
Sharp 32" Aquos 1080p
Benq W500 Pojector.
Watercooling:
2 x EK Supreme HF, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, XSPC GTX 580 FC block, EK Coolstream XT 220 RAD Gelid Wings Push - CM R4s Pull.
  #23 (permalink)
Old September 10, 2008, 03:27 PM
Damn
thats a good case
i have the freezone Elite and thought it is already pretty good
but this thing just kicks the Elites butt
hey btw
there is a typo on the Conclusions page
first line of the third or forth paragraph (forgot)
you typed "inly" but im pretty sure you meant only
hahaha
  #24 (permalink)
Old September 10, 2008, 04:42 PM
cwestwell's Avatar
Well, the system retails for 850$ at NCIX; now, look at it this way:
TJ07: 325$ with no side windows.
MCP-655: 70$
Micro-res: 20$
PA120.2: 120$
Apogee GTZ: 70$
Tygon, 1/2" 10 feet: 40$
SFF21Fs, x4: 60$
Total: 705$. Add barbs, clamps, liquid, etc...
For a system that is better than the wc setup I just proposed, the 145$ diffference may well be justified.
Well said.......Indeed
I have been looking into many many options for my home setup I have slung a few WC systems through my old store but I am much more fussy about what is in my house...So I have been looking at this monster U2-UFO case to accompany this monster WC solution and Im looking at almost $1000 solution to get the results I want ....and I would be huge...really huge....so Along comes a great detailed review like this for a product that delivers what I want in a much smaller package and bang I think I have found my golden goose of glory. Now I am looking at throwing the Boreas 12tec Barebones into an X2000 hmmmm.....
also release more info on the Coolit 4870X2 cooler...come on give one to HWC
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
  #25 (permalink)
Old September 10, 2008, 06:20 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
FYI, unit without the case seems to be $550 @ NCIX:
NCIX.com - Buy Coolit Systems Boreas 12 Tec Chiller W/MTEC Control Center Plumbed for Single CPU 1/4IN Barbs - BOR1C In Canada.
  #26 (permalink)
Old September 11, 2008, 08:47 AM
barrolde's Avatar
CoolIT Systems Rep.
True story.. there was a little confusion when it first got sku'd up but its all sorted now. NCIX has the product reviewed, the product reviewed sans chassis and will likely soon have a 'barbones', unplumbed version for those who want to put a chiller on the return side of their existing loop.
cwestwell - I'll be sending our 4870X2 solution over to the Canucks asap.
Life is a Garden... Can you Dig it?
  #27 (permalink)
Old September 11, 2008, 08:54 AM
SKYMTL's Avatar
Will the unplumbed version come with options for different barb sizes or will it still be based off 1/4"? If you keep the price to within reason, this will be an excellent option if people wnt to replace their rad.
  #28 (permalink)
Old September 11, 2008, 01:03 PM
barrolde's Avatar
CoolIT Systems Rep.
The unplumbed version will ship with 1/4" barbs only. We are doing our best to show that whether using a radiator [PURE] or a chiller [Elite / Boreas] on a CPU or GPU (which you can decide for yourself when you get our 4870X2 and GTX 280 blocks :) that 1/4" provides sufficient thermal bandwidth.
For those of you who would consider replacing your radiator with a chiller... I'm sure you have lots of questions. What happens to the Boreas (and your loop) if you reduce to 1/4"?
Hmm.. sounds like a job for HWC.. what do you say?
  #29 (permalink)
Old September 11, 2008, 02:11 PM
cwestwell's Avatar
Just to make sure I understand this I can buy the boreas barbones and hook it up to a swiftech pump and Appogee GTZ block or any existing WC setup tubing and all. Do I need any special coolant or will any of them do the trick.
  #30 (permalink)
Old September 11, 2008, 02:42 PM
You'd need tubing reducers most likely(or new fittings if you change entire loop to 1/4-inch), but otherwise it can replace rad, or go after rad in loop to further lower coolant temps. Standard coolants all apply.
