Old September 8, 2008, 04:39 PM
Default First Watercool - Advice?
Hi all,
I'm going to take my first plunge into watercooling so I'm hoping to get some good advice on how to proceed. I've assembled a parts list that you can hopefully take a look at and make recommendations on or if you see anything that I am missing that I am going to need to pick up. I haven't figured out what kind of case to get either. Is there a good one that is both functional and has the looks?
CPU Block: D-TEK Fuzion V2 with accelerator nozzle kit, 5.5mm nozzle
GPU Block: EK-FC4870X2 CF Nickel
Pump: Laing DDC 3.2 with custom XSPC Premium Laing top
Radiator: Feser X-Changer with aerocool xtreme turbine fans
Tubing: Tygon R-3603 7/16" ID with primochill anti-kink coil
Barb fittings: EK High-Flow fittings
Zip ties
Reservoir/T-Line: Undecided
Coolant: Undecided (Make own with distilled water + additives?)
Is there any sort of tools I can pick up that will help me for modding the chosen case to accomodate all this? Dremmel, hammer, saws, laser beams?
The configuration I'm going to be looking at is cooling the CPU, single-card GPU (though maybe adding a second in the future) and the motherboard (Asus rampage extreme x48 which has a fusion block attached). Any good ideas on where to proceed from here? Thank you!
:help:
Old September 8, 2008, 04:52 PM
sswilson's Avatar
For case modding tools... dremmel is obvious. Hole saws are nice to have. Some jeweler's files also come in handy for cleaning up your cuts (the ones on your case... not the ones on your hands.... :) ).
It's also handy if you can get your hands on a cheap PSU for running the pump during leak testing.
Old September 8, 2008, 04:54 PM
Cptn Vortex's Avatar
feser is a great rad... but kinda expensive... If you dont already have it yet, get a MCR320, or 2
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS
i7-5820K @4.2GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
Old September 8, 2008, 05:39 PM
Dwayne's Avatar
I second the jeweler's files. I wish I had some when I modded my case. I only had a large clunky file and one small one, but not small enough. The dremmel with the right sanding tip will help too.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Samsung - 960 EVO NVMe 500 GB Boot : Muskin 1 TB Reactor SATA : Crucial MX 500 1 TB SATA m.2 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA RTX 2080 XC Ultra Gaming
HTPC - MSI B360-M Gaming Plus : i3 8100 : 8 GB G Skill Ripjaws V Series: EVGA 500W 80plus : EVGA GTX 1050 SC : NMedia HTPC Case: Adata 240 GB SSD Boot
Tablet - Asus Surface clone
Wife's Rig - MSI GL72M 7RDX
Old September 8, 2008, 06:20 PM
Default Reply
Rumour has it that the nozzles for the V2 make it actually perform worse... Well atleast that's what I've heard. Next on the chopping list is the fans and radiator. The Aerocool fans suck, go with some Scythe S-Flexs. The radiator isn't worth it, like the Captain said. Tygon is overrated IMHO, buy some Primochill Primoflex LRT PRO. Get some compression fittings since you appear to want to go all out. Zip ties suck BTW IMO, worm clamps if you're not using compressions.
If you don't like compression fittings, keep the fittings. But if you do want to use compression fittings, make sure you get either the Swiftech Apogee GTZ or the EK Supreme. The Swiftech MCRES-MICRO is a great res, unless ya want something more fancy. If so get an EK Multioption RES of your size. Coolant wise, I'd go with some Feser One. Heard great things...
Old September 8, 2008, 06:47 PM
ebdoradz's Avatar
advice since i did my 1st watercooling projet couple weeks ago,
take your time, seriusly take relay your time .... i had the to unplug the computer everynight and do a test fit with pump and stuff without remoming any components, i was also doing sketch of my case layout everynight after 10 days i have deide to pull thing apart and install all the waterblocks
i still wasnt sure of my rad mounting so i was trying all position with cutting anything and when i was finaly decide 3 days after i took out the dremel and install it.
i wanted to go with t-line, memebers here recommended me a reservoir, i have order both of them. and i finlay went with the fill port ... its a pain in the ass to fill but its take less space, and to my taste look cleaner.
heres my worklog
http://www.hardwarecanucks.com/forum...g-project.html
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old September 8, 2008, 07:25 PM
JD JD is online now
I'd go with Primochill ProLRT tubing and Bitspower fittings, possibly compression ones where they will fit.
Areocool fans? No. Get something like Scythe S-FLEX or Noctua NF-P12.
Go for the Apogee GTZ as well, performs a bit better and IMO looks better.
I wouldn't bother using the Fusion block that comes on the motherboard. I believe it's aluminum and mixing metals is bad. If it's copper, then fine, go for it though I don't know how effective it's really going to be.
For all the stuff though, you're definitely going to need at least a 120.4 radiator, though 2 120.3s would be even better, but then you run into the issue of where to mount them.
I run Feser One in my system and it does the job. Gives it some colour too. It is sticky to clean up though and can stain your clothes/carpet easily I'd think. I don't think it's really caused any tubing discolouration but I can't really tell anyways.
