Just an update on those primochill barbs we were talking about earlier in the thread..... Just gave them a second try on a different loop and experienced the same issues. Seeing as how I've used 3 or 4 different types of 1/2" barbs without a single issue like this I'm gonna call them out as being crap. (Can't say I didn't try to give them a fair shake..... :) ).
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
Yeah I thought last time I saw NCIX was basically throwing them out for cheap..
__________________ Intel E8400, Biostar TPower i45 Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb Lian Li V1000, Enermax Galaxy DXX 1000W Samsung 931BW 19" LCD, Logitech MX Revolution WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block, Swiftech Micro Reservoir Black Ice GT Stealth 240 Rad w/Zalman ZM-F3 |
Any more updates/pictures on this? I'd love to watercool my 900 eventually and really like the front rad placement idea.
__________________ P5K SE // Q6600 @ 3.2ghz // Arctic Cooling Freezer 7 Pro // 2g Dual Channel Kingston Hyper X // Palit 4850 // Antec NineHundred // Corsair TX750W PSU // Viewsonic VA2226w // Logitech G15 // Nostromo N52 And It's a constant battle between all my hobbies to decide where I spend... |
What would you like to see? I've misplaced my charger for my camera, but I can borrow the wife's cam when she gets home. Actually, there's a been a few changes since I updated this last. New mobo, new Blood Red fluid, put a Maze 4 on my 4870 to get rid of the turbine whine . I'll have to take some new pics.I will say after having this up and going for a couple of months that the drain line was a good idea. I've drained the loop 3 times while leak testing, once to change the fluid from clear to red, and once more when I put the Maze 4 in the loop. I'm still waiting for Petra's to get the Red LED Yate Loons back in stock, apparently they got shipped blue instead from overseas.
__________________ Intel E8400 Biostar Tpower I45 Diamond HD4870 512mb G-Skill DDR2-1000 4GB Creative Xtreme Audio PC P&C 750W Quad Silencer Antec 900 Logitech G-15, G-5 WC Loop: Swiftech Apogee GTZ Danger Den CPX-Pro, Maze 4 GPU Black Ice GT Stealth 240 Rad |
I'd really like more detail on the rad mount you did. :) The rest is pretty straight forward I think. Thanks!
| Quote:
| Quote:
No rush, one day if you open up again i'd appreciate One of my winter project, and winter is at our doors
Well, as long as I was taking 1 picture, I thought I'd update the whole project. Here's how the blood red Fluid XP looks, and you can see where I mounted the pump: ![]() The Maze 4 mounted on the 4870 with Enzotech Ramsinks: ![]() Sorry about the glare from the battery, and yes I put ramsinks on the vrm's too. The whole loop with the new Biostar. I need to cut one more hole to hide the 8-pin cable. ![]() Skyllz, here's what's visible from the front of the machine: ![]() Just realized how dusty my rad is. Anyway, you can just see the end of a bracket at the bottom of the picture. This might give you a better idea of what I did: ![]() Pretend the box with barbs is really a rad. I drilled a hole large enough to screw the bracket to the rad. Top red dot. I then put the rad in place with both brackets on, then marked the holes on each bracket (bottom dot). Drilled a smaller hole and used self-tapping screws to mount the bracket to the mounting cage. The brackets I made are from 1/8" aluminum and are 1" x 2" approximately. I'm sure you could find something at Rona or Cdn Tire, I just had some scrap left from my last fabrication project.So the brackets mount to the barb side of the rad, and the fans mount to the other side blowing air into the case. I still have a rear exhaust fan and the big 200mm fan on top going at lowest speeds. My CPU idle temps are 26-28 degrees, and load temps are 38-40 degrees with the GPU block in the loop. My GPU now idles at 35 degrees, down from 78 with the stock fan setting and 55 with 30% fan speed.
Awesome, thanks for the pics, very easy to figure ou now!!!!!
| Thread Tools | |
| Display Modes | |
