You may want to think about that koolance block. Supposedly theres a problem with some of them that the plugs are stainless steel and rust fairly quickly.
__________________ CSE: Lian-Li PC-A70 MOB: Biostar T-Power I45 CPU: Intel C2D E8600 @ 4.3ghz RAM: 4gb g.skill pc2-8000 GPU: XFX 8800 GT Alpha Dog Edition PSU: PC Power & Cooling 750w Heatware: My Heatware |
| Quote:
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
@ 3.0 Charlie: Yes, the pump is humming along again. No bubbles visible in lines, a small amount of foam in the top of the res. @enaberif: Ya, MpG gave me a heads-up about that, but because I've got PC ICE, not distilled water, it apparently shouldn't be a problem. But I will look for some replacement caps when I order more stuff. I'm glad I've got that drain line in there, it makes it soooo easy to drain the loop. Although I could dismount the res and turn it over to drain too. Edit: sswilson, yup, you really have to inspect the barbs to make sure the o-ring is seated properly. I learned that one about 14 seconds after I started to fill the loop for the first time.
__________________ Intel E8400 Biostar Tpower I45 Diamond HD4870 512mb G-Skill DDR2-1000 4GB Creative Xtreme Audio PC P&C 750W Quad Silencer Antec 900 Logitech G-15, G-5 WC Loop: Swiftech Apogee GTZ Danger Den CPX-Pro, Maze 4 GPU Black Ice GT Stealth 240 Rad |
![]() Well, spent a couple of hours this morning getting everything inside the box and doing some cable management. I inverted the PSU to get the cables closer to the new hole as there's no openings on the top or bottom of the Silencer. I won't be showing you the back side of the mobo, or the bulging back cover. ![]() Idle temps with the Tri-cools on low - 26 degrees. Load under OCCT - 32-33 degrees, running 9x435 @ 1.34 V. I was at 45 degrees with the Ninja. Now to lay the boots to it, see how far I can push the old E8400. This will be it for now, until I get some dye-bombs and new fans. Then maybe a GPU block? Not sure, but I really enjoyed this project. Thanks for looking.
. The top barb is leaking on my res again. Steve, was your res leaking with the Primochill barbs? I'm wondering if it is an issue with the fit of the barbs in the Swiftech res. It's not a bad one, one drip every 5 minutes right now. Off to drain the loop again. Sigh.
any purticular reason you didnt choose the Swiftech metal barbs SugarJ?? Nice looking block btw.
__________________ Intel Xeon E3110 @ 3.0ghz XFX 8800 GT Alpha Dog Edition Asus P5Q-E Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v OCZ 600W GameXstream Seagate 7200.11 500gb Seagate 7200.10 320gb Antec Spot Cool Logitech X-230 Samsung 32" 720P HDTV Coolermaster Cosmos S/ Swiftech Mcp655/ MCR-320-QP/ 6X Noctua NF-P12'S/ Swiftech Apogee GT/ Swiftech Mcw-60/ Swiftech Micro-Res. |
| Quote:
@Dashock: I really liked the low profile look of the Primochill's, which I'm now really regretting. @sswilson: I have one untouched barb that I'm going to try, if I have issues then the DD barbs I have go in the res. I liked the Primochills because of the low profile and the fact I can get the tubing back off without having to cut it. No issues with my pump or T-line barbs, at least yet.
Well, you just unknowingly convinced me in not buying those barbs. I like to try new stuff, but this time around I think I'll pass...
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
| Thread Tools | |
| Display Modes | |
