I bought a block from a member on this forum that had full of black deposit in the D-TEK v1, i managed to dissolve a bit of it with vinegar and salt, but this is quite slow as it only works when the salt is in direct contact with the metal, but not yet dissolved in the vinegar. The precipitate was purple. Because of this I assume the water addititve he used was that purple stuff, iodine based. How can I get rid of this black residue on the block? I have my friend obtaining me some powerful HCl but that will take a while before he can get it to me.
I do not think that a strong acid will dissolve iodine any better than plain water but it has been a long time since I studied chemistry. Have you tried rubbing alcohol? That is the solvent used to make most medical iodine products.
__________________ He either fears his fate too much, or his deserts are small, that dares not put it to the touch, to gain or lose it all.
- James Graham
Tried, and nail polish remover. Best thing was vinegar + salt, followed by toothpaste, the others did absolutely nothing, even after soaking in it for 1+ hours!
If you can't get it off, it's likely it is not impacting thermal performance anyway.
Got most of it off, but theres still some at the bottom - I'm going to settle for this, do you know if those screws you forgot to send me are metric or SAE?
