Old August 28, 2008, 02:41 PM
MpG's Avatar
MpG MpG is offline
Oh? So the DB-1 is actually the re-badge?
Old August 28, 2008, 03:07 PM
3.0charlie's Avatar
Yes. Good pump.
Hydro-Quebec is salivating...
Old August 28, 2008, 05:35 PM
MpG's Avatar
MpG MpG is offline
Heh, I know, I'm running one for my chipset cooling. I had always been under the impression that D-Tek was manufacturer, while DD's model was the rebadge, that's all.
Old August 29, 2008, 01:57 AM
Linus's Avatar
D-TEK released the DB-1 BEFORE Danger Den released the CPX-1
Old August 29, 2008, 12:26 PM
Apollo4g's Avatar
Nice little thing, wouldn't mind picking up one for my chipset loop or even a gpu loop.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old August 29, 2008, 03:30 PM
sswilson's Avatar
Just a heads up for anybody purchasing one of these... I just got mine in and while it does include the barbs, and the shock absorbant (rubber) mounts, it doesn't include any mounting bolts/nuts.
Not a big deal, but it would suck to open all of your new WC parts on a sunday only to find out that you can't mount it.
Edit.....
Since these get their power from a motherboard fan header, you'll also want to ensure that you've got a molex --> 3 pin fan adapter for leak testing, otherwise you'll have to power up the motherboard without knowing if the loop will leak.
Old August 29, 2008, 03:34 PM
lowfat's Avatar
Originally Posted by freakgeek1337 View Post
Correct, the CPX-1 is just a DB-1. They're identical, pretty much... Also tests by martinm210 at XS show that the CPX-PRO is better than a stock DDC 3.2. That means something.
I didn't know this. How loud are they?
Mael
Big Lian Li
Forever Alone
Old August 29, 2008, 03:50 PM
SugarJ's Avatar
sswilson, which pump did you get? The CPX-1 or the CPX-Pro?
  #19 (permalink)
Old August 29, 2008, 03:52 PM
sswilson's Avatar
CPX-Pro.
Not really sure when I'm going to get a chance to put a loop together with it though. I bought it because I didn't want to orphan the Apogee GT when I install the GTZ. :)
  #20 (permalink)
Old August 29, 2008, 07:55 PM
SugarJ's Avatar
I just found the CPX-Pro for $46.01 on Direct Canada. Placed an order for most of the rest of my parts tonight.
