Old August 17, 2008, 06:40 AM
cdn_Madrach's Avatar
Default What exactly does this do?
Probably a noob question but what is the purpose of this part?
PT DDCT-01s Custom Delrin DDC Pump Top w/ Barbs - PTDDCT-01
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old August 17, 2008, 06:54 AM
JD JD is offline
It replaces the stock top on the MCP350/355 pumps also known as Laing DDC. It greatly improves the flowrate of the pump, though the XSPC acrylic top out performs Petra's.
Unfortunately I don't have any good picture of the pump by itself. This is about the best I have:
That's the Swiftech MCP355 pump which looks like this stock:
Old August 17, 2008, 08:42 AM
Thanks
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old August 17, 2008, 08:50 AM
Pic with pump and that top:
FS: Watercooling Stuff
Old August 17, 2008, 09:18 AM
Thanks for the pic. So it is used for both better flow and change inlet/outlet one just one benefit/option.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old August 17, 2008, 09:19 AM
Both.
Old August 17, 2008, 09:20 AM
MpG's Avatar
MpG MpG is offline
The Laing DDC series of pumps (aka Swiftech MCP350 and MCP355) are great units, but their stock housing really slows them down, especially on the inlet. The aftermarket tops open the pump up and let them work far more efficiently, improving the pressure AND the flow rates right across the board. They also let you choose what size of barbs to use, rather than be stuck with 3/8" sizes.
Right now, XSPC's tops seem to have the edge, but it's not by a huge margin. Pretty much all the tops show a noticeable improvement over the stock configuration.
Old August 17, 2008, 10:43 AM
kruzn4evr's Avatar
Where do you buy the XSPC tops?
Old August 17, 2008, 10:59 AM
Thanks for the replies guys...was actually looking at water cooling parts to maybe water cool my HTPC and didn't want a large pump but also did't like the barbs on the 350 and 355's.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old August 17, 2008, 11:21 AM
I have a 350 with that top for sale ;) And a pa120.2 rad :D
