Old September 10, 2008, 07:40 AM
Originally Posted by Cptn Vortex View Post
Great to see it is all installed!! Cant wait to see some temps!
Ok sir, temps aren't very great, I am kind of concerned and would like some help.
on stock the idle temp is around 35-37C and load goes till about 45-47C. I used Coretemp for the temps. Somethings I looked again, the fans on the radiator are actually blowing air towards the rad and not backwards, one question on that, Vortex I have the same Zalmans spin from 800-1800rpm, not does it spin full speed if connected straight to a molex (via 3 pin to 4 pin molex).
Maybe I can further do is, drain the loop and re-fill the liquid. Maybe I'll have to replace the rad do try it out, the one I'm using is an old one, and I think its taken a hit, I'll try and get some pics if possible. Currently its just a cpu only loop, so video card doesn't come in the question.
I'll also wait for the next HWC sale, if there is a cpu block on sale, a good one, I might pick it up, the Apogee GT I have, its a nice one, but frankly its also been sitting for ages before I had put it to use again.
Any other suggestions please ?
Old September 10, 2008, 09:11 AM
3.0charlie's Avatar
Stock idle temps are high. Fans are fine too, though I don't know about the fan speed; usually a straight connection means the fastest speed. No need to drain the liquid, but I would try a block re-mount. The GT is just fine: worst case remove it from the loop and open it up to clean the inside.
Hydro-Quebec is salivating...
Old September 10, 2008, 09:25 AM
Very good idea. Also I was deicind to bow my GT, where do I get the other round ring, there was no black round rings that came with the block. If I'm thinking wrong, what exactly is bowing then..
Old September 10, 2008, 09:45 AM
Dashock's Avatar
Mine came with a thicker black ring it should have come with yours as well?
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old September 10, 2008, 10:01 AM
I'll recheck, but as far as I remember I didn't see any. Oh and I was one of the buyers who got their GT's in the Box, rather than a plastic clamshell.
I'll check when I get home.
Old September 10, 2008, 10:38 AM
3.0charlie's Avatar
My Apogee GT came in a box too, and the o-ring was inside a plastic bag. Be ready to swear just a little, 'cause re-assembly of the block withthe larger o-ring is "interesting"...
Old September 10, 2008, 10:41 AM
I'll re-check, sorry its probably hard to remember for you. You know they are different zip lock bags, each labelled for different mounting hardware, and one with the barbs, do you remember which bag it was ?..
I hope I have it.
Old September 10, 2008, 10:49 AM
3.0charlie's Avatar
It was alone in its bag, with a sheet of paper showing the correct block orientation.
  #19 (permalink)
Old September 10, 2008, 11:09 AM
Freeze o-ring as it makes it sticky and then put it on the block. Goes a lot easier, took me all of 5 minutes.
But yes I fought with the stupid thing too.
