Old August 10, 2008, 09:20 AM
ebdoradz's Avatar
Default best setting ofr a MCP655
i have finish my watercooling project,
the pump is currently put on setting 4 and its the loudest part of my system, does lowering it to setting 3 will give me enough cooling power?
i have fuzion v2, fuzion gfx v2, pa120.3 rad, mcp655
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old August 10, 2008, 09:26 AM
Babrbarossa's Avatar
Shouldn't be that loud on 4- maybe after a bit of break-in, it will quiet dwon. I have heard of the odd mcp655 being particularly noisy though.
Old August 10, 2008, 09:32 AM
ebdoradz's Avatar
ok,
i have raise my fan speed a bit, so now both fan and pump are doing the same noise, ....
Old August 10, 2008, 09:34 AM
Supergrover's Avatar
Yeah I run mine at full and cant hear it over the case fans.
R.I.P.
Old August 10, 2008, 09:40 AM
MpG's Avatar
MpG MpG is offline
There are more than a few cases of setting 1 offering the same cooling performance at setting 5, especially on low-restriction setups. The reason is that many modern waterblocks exhibit virtually zero improvement once the flow increases beyond the 1-1.5gpm mark, and the heat dump is noticeably lower.
I'd suggest you set the pump to 5, load the hell out of your computer (Prime, OCCT, Furmark, whatever), and wait for temperatures to stabilize. Then change the speed on your pump, and see how things change.
Old August 10, 2008, 11:13 AM
Default Reply
Perhaps there are some air bubbles in your loop near your pump. That's just a thought though...Or maybe your pump is causing vibrations to the case, therefore causing noise.
Old August 10, 2008, 11:32 AM
I belive he's running a res so doubt it's air in the system
R.I.P.
Old August 10, 2008, 07:12 PM
ebdoradz's Avatar
change my mind and went with a t-line,
but there no bubble in my system.
Old August 12, 2008, 01:28 PM
Apollo4g's Avatar
best thing is to leave your system on idle for a while. And test your temps on each pump setting.
My guess is with a d-tek setting 5 will give you your best temps, try the settings on load as well.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old August 18, 2008, 12:22 PM
Dashock's Avatar
Em Ebdoradz i had the same problem as you in the begining i could heard the Pump but i was using a Dual rad with intergrated res and after 2 days of all the bubbles getting out it went silent and after i redid the loop again, this time with a triple swiftech rad and this time with a res it was silent after just a few hours i cannot hear it and i have the model without the adjustment to speed so id run it on full why not.
Also make sure you properly secure the pump i used the sticky pad as a silencer so the case would not vibrate too much.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
