Old August 18, 2008, 05:37 PM
ebdoradz's Avatar
its on setting 5 now and it look OK
after 1.5 hrs of BF2 my temp where cpu, 38, vga 42 full load aint bad at all. since my gpu was running 90 ++ when playing bf2
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old August 18, 2008, 05:40 PM
Cptn Vortex's Avatar
Very nice temps!
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old August 19, 2008, 09:26 AM
ebdoradz's Avatar
temp drop of over 45C between the stock ATI cooler and the fuzion gfx 2,
cpu temp look the same on air then with my lapped arctic coolier freezer
but just for the silence of the vga card, and its low temp it worth it
Old August 19, 2008, 12:58 PM
lcdguy's Avatar
he he he, sort of a hi-jack. but i leave mine between 4-5 but sinc i have 3 ultra kaze fans noise is a moot issue :). Btw my temps are killer.
CPU sits around 31 idle and around 40 load. both gpu's sit around 28 and 31 idle and around 40 ish on load :)
Old August 19, 2008, 03:11 PM
ebdoradz's Avatar
nice temp but those 3850 are running cooler then the X1950XT
im still @ 41-42C under load for that hot card
Old August 19, 2008, 05:50 PM
lcdguy's Avatar
did i mention i was using a thermal chill pa 120.1 :). also i used the same rad and pump to chill my x1900xt :)
