  #21 (permalink)
Old August 10, 2008, 05:19 PM
Originally Posted by lowfat View Post
He is right for most parts however they do make a whole bunch of different sized tubing.
You can get:
3/8ID 1/2OD
3/8ID 5/8OD
1/2ID 5/8OD
1/2ID 3/4OD
and so on.
The thicker the wall the less likely it is to kink, however it is stiffer and obviously thicker. You really do not need coils on 3/8ID 5/8OD or 1/2ID 3/4OD as the walls are thick enough.
Thanks Freak, guess you should see this though ^^, lowfat's description is even more clearer.
  #22 (permalink)
Old August 16, 2008, 06:51 PM
Dashock's Avatar
I used 7/16 tubing as well on the recomendation by Captain Vortex and it works awesome on normal swiftech barbs but put the tubing on the Pump barbs is literally a pain in the ass i totally put the tubing in boiling water for 3 times as long as i did for the swiftech barbs and it wouldnt go i hand to end up enlargening the hole with a pair of scissors which i do not think is a good idea or recomend might thin out the walls to much and cause a leak maybbee.... But dam was it hard to put it on the pump.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
