Old August 9, 2008, 02:15 PM
turtletrax's Avatar
I grabbed 30' of Primochill Black and am pretty impressed with it so far. Will be finalizing the rig next week so that is when I know for sure if I like it or not. I have seen the black with green colis and it looked pretty sick.
I might look for another color to see if anything else looks as good.
"It's time to kick gum, and chew ass. And I'm all out of gum."
Dick Kickem
Old August 9, 2008, 02:31 PM
Default Reply
I knew it! If Linus, Apollo4g, and this "Navanod" dude confirmed it, so it's got to be real. At first I didn't believe in the hype either, I remember Linus spamming the word awesome. But then I say the price and that's when I knew it was worth it, and the story goes on...
Old August 9, 2008, 08:34 PM
ebdoradz's Avatar
i just finish to watercool my computer and i used 7/16 masterkleer tubing and it did a great job on the bards....
gonna use it fo rmy next build too
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old August 9, 2008, 09:30 PM
JD JD is offline
I bought 3/8" ID 5/8" OD Primoflex ProLRT clear tubing and it is nice and clear (no ugly writing either) and bends very well. Better than I was expecting since I bought tube coils and ending up not needing them at all. However my tubing is a bit sticky like some people have mentioned. Sure it attracts dust a bit more but that just forces you to keep your PC clean
Old August 9, 2008, 10:26 PM
Default Reply
What's the difference between 1/2 and 5/8"? Would 5/8" give a tighter seal?:help:
EDIT: I was looking at Primochill Black Tubing and was wondering which was better. 1/2" and 3/4"OD or 3/8" and 5/8"?
Old August 10, 2008, 01:16 AM
lowfat's Avatar
1/2ID and 3/8ID are completely different. If you go with 3/8 you need to use 3/8 barbs. I myself use 3/8ID 1/2OD because I hate big and bulky tubing.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 10, 2008, 11:16 AM
Default Reply
Uhh lowfat? I was talking about 1/2" and 5/8" tubing, what's the difference?
Old August 10, 2008, 03:03 PM
I think you're pretty confused, lowfat was right. Here is the thing.
1/2" tubing has an outer diameter of 3/4" (OD)
3/8" tubing has an outer diameter of 1/2" (OD)
7/16" tubing has an outer diameter of 5/8" (OD).
I believe I remember seeing Clearflex 3/8" tubing having an outer diameter (OD) of 5/8" also.
  #19 (permalink)
Old August 10, 2008, 04:19 PM
Default Reply
Oh thank god for Miggs! That chart is sooo clean!!!I understand!!!
/end crazy rant
  #20 (permalink)
Old August 10, 2008, 04:39 PM
lowfat's Avatar
He is right for most parts however they do make a whole bunch of different sized tubing.
You can get:
3/8ID 1/2OD
3/8ID 5/8OD
1/2ID 5/8OD
1/2ID 3/4OD
and so on.
The thicker the wall the less likely it is to kink, however it is stiffer and obviously thicker. You really do not need coils on 3/8ID 5/8OD or 1/2ID 3/4OD as the walls are thick enough.
Queen of Dreams WIP
Big Lian Li
Complete
