Primochill Ghost Fittings Just a heads up... I don't know what happened, but it doesn't seem to make a good seal on my XSPC top anymore. It was leaking everywhere today. Even once I got the tubing off, the fitting itself was still nice and tight and I had to use pliers to remove it. Anyways I rammed a 1/2" D-TEK barb into my 3/8" tubing and I'm using that on my pump now. Though it's rather unsafe since the tubing is only on the tip and not fully covering the entire barb however seeing how tight it is I doubt it'll be a problem. Least it's not leaking though. Of course doing this made a mess of Feser all over the place, so now I got to let my PC dry out for a good 24 hours just to be safe. Guess I'll be getting those Bitspower compression fittings I wanted... |
Just a tip, using contact cleaner on your board and other components is a good way to get the Feser one off once it dries. That stuff tends to leave a pretty sticky residue on things it gets spilled on. |
| All times are GMT -7. The time now is 04:54 AM. |
