Old August 3, 2008, 10:37 PM
turtletrax's Avatar
Default TJ-07 dual loop help....
Hey guys.
I have been bitten by the upgrade bug and purchased a new TJ-07/GTX 280/HX-1000/EK Supreme/EK GTX FC block and need some advice/point in the right direction.
I have 2 DDC-2's with petra tops that have not given me any trouble in the year and a half I have had them, so I dont think I want to part with them, so those will be the pumps. The rads I have are where the trouble starts. I have a PA 120.2 and a HE 120.3. The HE 120.3 does not have direct fan mounts, so I have to use the shroud I have, but it all fits in the bottom except the radius the Primochill 1/2" black tubing I have is too tight to use the EK G3/8" Barbs coming straight off the rad.
So my next option would be to use a 90 on at least one of the rads, perhaps both . I cannot find anything on them on any of the retailers in Canada. Does anyone have any thoughts on this dilemma?
Second is my reseviors. I have cheapo MC-Res Micros, and want to go with EK Multi-option 250. As I dont think I have room for two, would it be a bad idea to go with one and combine loops to run off the same res?
I am starting to regret going back to 1/2" ID hose as I think this system will get too bulky inside. I have searched through quite a few TJ-07 builds here and dont seem to be finding the answers I seek. Perhaps thosewith TJ-07's can give a brother a helping handon getting this sucker finnished.
P.S. - this is a copy of my post on XS. I didnt want to leave you guys out ;)
In progress: Other hobbies.
Old August 3, 2008, 11:28 PM
Default Reply
I believe it would be a bad idea because then the heat in the liquid from the first loop would blend with the other loop's liquid. I would advise that you keep the Swiftech MCRES-MICRO, hide it somewhere in the case and use it for one of the loops. If you want the EK Multi-Option 250 buy one and use it for the other loop. That way you have two loops. The EK Res can be mounted on the mobo tray btw.
Nope, sorry I don't own a TJ07. But I do know that many people still use 1/2" tubing for their TJ07 builds. So I personally would keep with the 1/2", it is my favorite size.
I'd help you solve this problem, but NCIX is down currently. I'll update on this soon, hopefully...
Old August 4, 2008, 09:13 AM
cyberspyder's Avatar
Buy your stuff from Petra's Tech...more selection than NCIX.
Old August 4, 2008, 10:27 AM
turtletrax's Avatar
Bought lots off Petra, nothing as far as G3/8" BSPP 90 degree 1/2" barb fittings.
Looks like I will be getting two EK 250 Multioption res's from petra and god only knows where to get the fittings.
My other question is what/where are the really good cable sleeving kits. All I can find are junk ones locally and I dont want to order some and find out it is junk too. Need a referance from someone.
Old August 4, 2008, 12:33 PM
For sleeving you want to be looking at Techflex. Sleeving kits are generally junk...much better to get the heatshrink and sleeve yourself as you can choose your colour and size. I recommend this site: Braided Sleeving, Expandable Sleeving, Wrap Around Sleeving or this one (where I get most of my audio sleeving from): https://www.solen.ca/pub/cms_nf_cata...lvbj0yJmZ0PW5m
Brendan
Old August 4, 2008, 01:29 PM
Sorry to go offtopic:
Does the shipping cost become more expensive, lets say ncix has a $25.00 ground shipping (trackable), how about Petra's.. I'd love to buy stuff from there, but shipping could be a big factor. Just like sidewinder and performance pc-s, have it for $26 somewhere around there but un trackable..
Old August 4, 2008, 01:48 PM
turtletrax's Avatar
Petras rocks. Take my EK GTX 280 waterblock. Was something like $144 in Canada (but no-one had one) and Petra's was $122 US. Take the little bit of exchange and add shipping it was like $148 and they shipped UPS and stated it was a gift with a $0 declaration. Went and picked it up at Canada Post and there was no duties or anything to pay. Plus you get personal email from real people who care about your shipment. I deal with Aaron and he even requests you let him know you got the package so he can rest easy after.
Top notch and well worth the little extra effort.
I also think you can track UPS packages with Canada Post.
Damon
Old August 4, 2008, 06:04 PM
JD JD is offline
Damon
You mean USPS. Don't make that mistake. UPS = Extremely high duty/customs and they wouldn't switch over to Canada Post after the border.
But yeah Petra's is great to deal with. I had the same kind of service from Aaron. I even kept changing my order on him daily so he had to keep making me a new quote. I would of felt bad if I ended up not ordering from him.
Old August 4, 2008, 06:13 PM
Lets say I spent about $55, and it was a 10lb box, shipping would be approx.. sorry I'm just trying to save myself a buck or two where I can, ncix is approx. about $15 for a 10lb box..
Thanks guys.. @turtle, I know you have plans for your setup, there is a wonderful worklog at overclock case mod who played with I believe the same case as you have, and it came out wonderful, I can't link coz' their site seems to be down, I will as soon as its up.
edit: Here is one of them.. TJ07 Case Mode
This one is a Lian Li case mode link, but they are pretty close to each other.. Lian Li V2000 Case Mod
Hope this helps.
Old August 4, 2008, 08:31 PM
turtletrax's Avatar
Doh, ya I meant USPS. I have had only one happening with UPS and it will be my last.
And ya Aaron is a helluva guy. I did the exact same thing to him and didnt even bat an eye. Well worth the shipping wait IMHO.
Hope this helps.
Thanks m8. I plan to take my time with this build and do it right. I will not be upgrading for awhile (and by a while I mean Nehelem LOL), so I can take the time to look around and see what others have done.
I was leaning toward something like this
I dont think I have the time/will/resources to go balls out and do the hydrojet cutting and paint. I just want top notch watercooling and done correctly.
