Old July 28, 2008, 06:43 PM
BALISTX's Avatar
Default Custom Water Cooling Setup
What parts would you recommend to water cool the following setup.
AMD Athlon 64 X2 5000+
9600 GT in SLI
Heatware
HWBOT
Old July 28, 2008, 06:54 PM
ebdoradz's Avatar
cpu = D-tek Fuzion v2
Gpu = D-tek Fuzion gfx v2
pump i would suggest a MCP655 or a MCP355 with petra's top
Rad i would either get a MCR320 or a PA120.3
for reservoir i could recommend a swiftech MCRES or a fillport
tubing : masterkleer 7/16 tubing
barbs= D-tek high flow metal barbs
i wioll post pics of my setup in a couple day when i t will be done.
which case do you plan to use?
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old July 28, 2008, 07:07 PM
BALISTX's Avatar
Coolermaster CM690. Thinking about mounting the rad on top inside if possible
Thinking about using these fans Blackfire4 UV LED 120mm Fan Sleeved - Orange
Specs 28.95 db and 77.70 cfm
Heatware
HWBOT
Old July 28, 2008, 07:10 PM
Infiniti's Avatar
If your using a dual rad, then you can get it to fit on top of an CM690 without any modding. If your using a triple rad, then you will have to find a way to reroute the top USB/firewire etc etc.
Old July 28, 2008, 07:14 PM
3.0charlie's Avatar
You don't need that much Jerry; that AMD chip and those 2 9600GTs don't have such a high heat load.
Pump: the MCP-355 is more than plenty.
The Apogee GT is fine too; bowing it is a plus.
The Swiftech MCR-220QP will take care of that heatload. And by the same token the reservoir.
After multiple tests, I strictly use 3/8" tubing (the Primochill stuff lately). No added value to use the 1/2": takes more space and needs wider bends than 3/8.
For the GPUs the Fuzion blocks are fine, don't forget the Unisinks to cool the MOSFETs and ram chips.
Hydro-Quebec is salivating...
Old July 28, 2008, 07:23 PM
BALISTX's Avatar
Thanks guys.
John, what about the D-Tek high flow barbs? What size?
What about Feser One Fluid UV Orange NON-CONDUCTIVE Water Replacement for Liquid Cooling -$19.99?
Heatware
HWBOT
Old July 28, 2008, 07:27 PM
BALISTX's Avatar
John, do you mean this stuff here Primochill Primoflex Pro LRT Clear 3/8IN ID 1/2IN OD Tubing (10 Feet) ?
Heatware
HWBOT
Old July 28, 2008, 07:29 PM
3.0charlie's Avatar
3/8", the same size as tubing.
You wish to stick with the orange theme, right? I never used anyting else than distilled water and the Swiftech stuff...
I just saw your SLI setup; the 355 pump may be bordeline for this. The 655 may be more appropriate.
Old July 28, 2008, 07:33 PM
BALISTX's Avatar
Yep sticking with the orange theme.
Will the MCR-220 still be enough for an SLI setup?
I've read good things about the Feser One fluid
Heatware
HWBOT
Old July 28, 2008, 07:35 PM
3.0charlie's Avatar
Originally Posted by BALISTX View Post
Yes Sir! Good stuff. Bends easily, does not kink. Much better than most products out there, except the Tygon which costs twice as much.
Now regarding the MCR-220QP, if you wish to mount it on top it may be a problem since it is also the reservoir. You may have to use the non-QP version and a Micro-Res.
Also, the MCR-220 is very potent; slap fans in push-pull config and it just shines.
