Old July 26, 2008, 05:56 PM
Default Gigabyte Poseidon 310 Case + Two ATI 4870's Graphics
Hi all, as the title says, does anyone know if having 2 graphics cards is possible when you have:
case (Gigabyte Poseidon 310)
the 3d Galaxy II Watercooling set?
Asus P5Q Deluxe Motherboard (not sure if that really matters, but it may help)
If not, what would you suggest for a decent LAN-able case? (I know it's not the best idea to take watercooling to LANs, but we mostly have small LAN's where its safe from bumping, etc) Cooling efficiency + weight are my biggest factors.
Thanks! :)
Old July 27, 2008, 05:24 AM
MpG's Avatar
MpG MpG is offline
I don't have personal experience with the kit, but the 3D Galaxy II is a single rad setup. Definitely inadequate for a pair of 4870's. If you're were satisfied with mediocre cooling (by watercooling standards), or a fairly high powered fan, a double rad MIGHT handle things alright.
Old July 27, 2008, 09:04 AM
3.0charlie's Avatar
You're heading into trouble with that kit and the components you wish to cool. Those cards have a heat output of over 70C at load, which will be too much for that Galaxy kit.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old July 27, 2008, 02:22 PM
Oh I'm sorry, I didn't mean COOL the cards...
I just mean FIT them. Like the place were the Water Storage goes is awefully close to the motherboard. I'm just wondering if I could even fit 2 4870's (without watercooling them) into that unit.
