Old July 20, 2008, 08:19 AM
WolfBane's Avatar
Well that looks to me to be a good pump!!!
I fear once i get this system that i will def start to upgrade to more loops , that being said this pump will handle the vid card as well as the NB?
Old July 20, 2008, 08:25 AM
JD JD is offline
I don't know about that. Your flow rate will be under 1GPM which isn't really recommended. The dB-1 is more geared towards a single block setup. At least that's what I've heard.
Old July 20, 2008, 09:18 AM
Synth's Avatar
I'm using this pump with a dual-rad and a single block: its totally inaudible and gets the job done. (http://www.hardwarecanucks.com/forum...thread-17.html)
However, I would advise against using it with multiple blocks: it's just not strong enough.
If you just want to get your feet wet though, it's a cheap way to get started !
Old July 20, 2008, 10:41 AM
WolfBane's Avatar
Yes for now i am wanting to tip my toe in the water cooling but down the road once i get comfy with my rig then i will buy a better pump and more blocks and try my hand at wcing itself! That being said i will buy my parts from members !
As i have threw Capt Vortex:)
I belive in helping the community that is helping me:)
Old July 20, 2008, 01:00 PM
BALISTX's Avatar
What about this kit here.
Swiftech H20-220 Apex Ultra Universal CPU Liquid Cooling Kit
Heatware
HWBOT
