Old July 18, 2008, 06:20 PM
WolfBane's Avatar
Default water blocks
Ok capt vortex is building me a rig!!
He is cooling the
Intel Xeon UP Dual-core E3110 3.0GHz Processor MM#895888
cpu but what else can o water cool in it ?
it will have a neo 2 msi board, 4870 vid card,750 gig hard drive . am i missing any thing else i can water cool ?
i want this system to be super cool so i won't worry bout heat at all :)
can i also cool the rem g.skill 5-5-5-15 4 gig ?
plus i like the windowed rez in the 5 1/2 bay what would that cost and wheer could i buy one ?
Also do those rezs leak?
Old July 18, 2008, 06:32 PM
MacJunky's Avatar
Unless you manually modify your PSU for watercooling(taking into consideration any live heatsinks) I think CPU, GFX, mobo, RAM and HDD is pretty much all you would want to do... unless you could find something in your optical drive worthy enough..
Old July 18, 2008, 06:35 PM
WolfBane's Avatar
Well i didn't know one could also water cool a psu!!!! but what blocks would i specificaly want for say my ram and hard drive etc etc
Old July 18, 2008, 07:09 PM
MacJunky's Avatar
Well, you can watercool plenty of things things.. Like a beaver! That is if you cared to make a suit for it with tubes and such running through it. It is mostly just a matter of fabricating or otherwise adapting any parts that did not exist before. Unless I am mistaken NASA uses water cooled/heated suits for "spacewalks" right?
It just depends on your determination, wallet, skills, etc.
Old July 18, 2008, 07:14 PM
WolfBane's Avatar
lol(beavers) lol but yes i think i def want to water cool at least the vid card as well i seen ek is making some blocks for the 4870 so i will def buy one of those and install that :)
Old July 18, 2008, 07:28 PM
3.0charlie's Avatar
So you'd better talk to the Cptn. and let him build your loop accordingly. You can add a block on the GPU (which I'll be doing as soon as they are in stock) and a block on the NB (which is very helpful in oc'ing). BTW, it's pointless to water cool ram sticks and HDDs. Not enough heat load.
Hydro-Quebec is salivating...
Old July 18, 2008, 08:03 PM
WolfBane's Avatar
Hey John i will ask Capt (paul) this monday as he is away this weekend , Do you know the price on that 4870 wb?
Also what does nb mean?(noob here)
Old July 18, 2008, 08:12 PM
3.0charlie's Avatar
Nope, still awaiting a call from NCIX about the price of the 4870 blocks (I need 2...). NB means NorthBridge.
Old April 19, 2009, 06:02 PM
Apollo4g's Avatar
what brand of blocks all?
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old April 19, 2009, 06:38 PM
sswilson's Avatar
WWT FOR ???????
These were the ones they ended up with.... :)
