  #31 (permalink)
Old July 18, 2008, 12:54 PM
Apollo4g's Avatar
mount the pumps back to back with the mounts. So you get a cube like shape.
Then flip them both on their side to get a flat surface to mount them.
Still confused? lol
EDIT: Yup bottom to bottom. So 2 355s back to back. Back meaning the underside of the pump.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
  #32 (permalink)
Old July 18, 2008, 04:04 PM
3.0charlie's Avatar
Got it. A block with 4 barbs shooting in the same direction. I like it.
Hydro-Quebec is salivating...
  #33 (permalink)
Old July 18, 2008, 08:58 PM
3.0charlie's Avatar
Well, the idea of having dual pumps side-by-side was interesting, but there was a problem: the MCP-355 has 3/8 barbs, and I need 1/2" barbs. And the fact that 2 more hoses would cross the inside of the case did not play well with me. So I took care of both problems. I bought this tonight: XSPC Cylindrical Pump/Reservoir Combo Products Model: XSPC-CYLINDRICAL-COMBO [XSPC-CYLINDRICAL-COMBO] : Performance-PCs.com, ... sleeve it and they will come. That should do the trick.
Only waiting for the PA120.2 and fans from Cptn. Vortex, and the 4870 FC blocks from NCIX. And some 7/16" tubing too - must... not... forget... that.
  #34 (permalink)
Old July 19, 2008, 10:48 AM
Apollo4g's Avatar
Nice, oh the 4870s! cant wait for mine lol.
I dont know where i saw it but there was a top, not sure if it was XSPC, that you could put 2 x 355 pumps on it. Combined.
EDIT: Found it! its an EK
http://www.ekwaterblocks.com/downloa...stallation.pdf
