Old July 16, 2008, 01:26 PM
Default Single rad $$$ > Dual rad $$$ why?
Already... I was thinking about adding a single rad to my loop inbetween the CPU and GPU's...
My question is....
why is this single rad so much $$$$$$$$ compared to a dual rad by swiftech??
heres the links..
http://www.ncix.com/products/index.p...re=Feser%20One
http://www.ncix.com/products/index.p...cture=Swiftech
why is the single rad twice (if not more) than the dual rad?? the quality that much better???
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old July 16, 2008, 01:32 PM
sswilson's Avatar
It is a much higher quality rad. I'm not sure about the Fesers, but the PA120s are almost twice as thick as a standard swiftech 120 which in theory offers almost as much cooling power as the thinner 220 rads.
Old July 16, 2008, 01:58 PM
Default Reply
These are MUCH harder to produce. Very spread out fins. And like SSWilson said, these are VERY thick. Overly thick...
Old July 16, 2008, 02:39 PM
lowfat's Avatar
Only $39.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 16, 2008, 03:01 PM
Cptn Vortex's Avatar
Yeah the swiftech series are BY FAR the best bang for the buck.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old July 16, 2008, 03:03 PM
when there in stock......
and my next question would be.... What would the temperature drop be by adding a single rad to the loop? 4-5 degrees maybe?
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old July 16, 2008, 03:11 PM
Hmm, that is hard to say. You are pushing quite the load on that dual rad as it is, so adding a single 120 will help. If it is placed somewhere good, like as an intake, it should get some nice cool air to help lower temps further too. 5-6 degress might be about right, but dont be too dissapointed if it is less.
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old July 16, 2008, 03:19 PM
3.0charlie's Avatar
...and if you wish to have one used, I have a spare Swiftech 120mm single, no barbs. It would be cheaper than to buy brand new and be disappointed.
Hydro-Quebec is salivating...
Old July 16, 2008, 03:33 PM
might take you up on the offer. The temps are not bad at all. the gpu's are under full gaming load max out at 59 degrees (top GPU) and the bottom GPU usually hits 54 degrees. The CPU idles around 35/32 degrees (according to PcWizard 2008 and core temp)) and touches 43 degrees under load. I have stress test the system at my current over clock and the temp gets up to 61 degrees (but I am slowly lowering the Vcore to help that temp). But thats at 100 percent load which I never reach playing my games... not sure if this is necessary or not, but I think my subconscience is getting bored already after water cooling so it wants to add a rad...
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old July 16, 2008, 03:39 PM
3.0charlie's Avatar
Your temps are fine, actually. But if you've been bitten, that's another story...
