  #21 (permalink)
Old July 16, 2008, 09:20 AM
Infiniti's Avatar
Originally Posted by jdrom17 View Post
I don't exactly find the Tri-Cools all that silent, well if you want some airflow that is. On low they are pretty quiet I suppose but without much CFM.
If you're gunning for silence, replace all your fans with those S-FLEX "E" models and you should be set.
No, I was just seeing if I can use two fans using only one power connector, and since they were stock fans, thats what I used.
  #22 (permalink)
Old July 16, 2008, 10:37 AM
Cptn Vortex's Avatar
Go with the Swiftec RAD. It is cheap and performs very, very good.
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS
i7-5820K @4.4GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
  #23 (permalink)
Old July 16, 2008, 12:16 PM
Infiniti's Avatar
Okay.
One question though, is there a place I can mount the MCR320 internally in the CM690?
  #24 (permalink)
Old July 16, 2008, 07:11 PM
JD JD is offline
Originally Posted by Infiniti View Post
Okay.
Perhaps in the top with some modding? The MCR will be the easiest to fit though since it's the slimmest. The stock fan mounts might line up even though I don't know.
  #25 (permalink)
Old July 16, 2008, 07:29 PM
I would either mod the case to put it up top, or just hang off the back with a Radbox or something similar
The Vortex H20
Asus X99-E WS
i7-5820K @4.4GHZ
RTX 2070
Watercooling:
  #26 (permalink)
Old July 16, 2008, 08:00 PM
Infiniti's Avatar
I just took some measurements and I would need to mod my CM690 quite a bit to get the MCR320 to fit at the top. The front USB/sound/mic etc.. would be in the way, so I'm just going to do what Cptn Vortex said and hang it off the back with a radbox.
  #27 (permalink)
Old July 17, 2008, 10:57 AM
Default Reply
Get an MCR320 and 3 S-Flex "E" and call it a day. I'd mount it on a radbox, you get more airflow.
