Old July 15, 2008, 01:07 AM
MpG's Avatar
MpG MpG is offline
Frankly, even Swiftech's MCR series will have better performance/fan at lower rpms. Not to say that the GTX480 is bad, but at low/quiet speeds, it's basically relying entirely on raw surface area to get the job done, rather than any particular optimizations.
Old July 15, 2008, 05:52 AM
Infiniti's Avatar
Ahh.. I see, so I should get the Feaser One rad? The PA120.3 is not in stock at NCIX anymore.. And if I get the Feaser One triple rad, would just three of those Zalman fans work? Or would there be much better performance with 6?
Old July 15, 2008, 08:56 AM
JD JD is offline
I think if you want performance and silence, you'd be best off with the Scythe S-FLEX E as per Vapor's mini-review: Fan Mini-Review: Battle of the Big Name ~50CFM Fans - XtremeSystems Forums
Unless of course you want to order some Yates from Petras as he has the best Yates apparently and I'm pretty sure it's the ones Vapor used.
If you get the Feser or even Swiftech rad, you could probably make do with only 3 fans. Using push/pull Noctuas on my Swiftech didn't really do anything for my temps but I had the fans anyways.
One other thought, why are you getting the Apogee GT? Might want to consider the D-TEK FuZion v2 instead.
Old July 15, 2008, 09:02 AM
Infiniti's Avatar
The D-TEK Fuzion V2 is not in stock at NCIX, and, I already have the Apogee GT as part of the Swiftech ULTRA water cooling kit, I just want to use a different rad other than the one the kit comes with.
Old July 15, 2008, 12:33 PM
I would say Noctua's unless you mind the price or the fact Noctua missed the memo computers stopped being beige 10 years ago.
Old July 15, 2008, 12:58 PM
Cptn Vortex's Avatar
I suggest giving Vapor's reviews a strong look. He does some very good testing. The Noctua's are good, but not as good as the Scythe S-flex or the Yate loons.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old July 15, 2008, 02:42 PM
JD JD is offline
I already linked that
Old July 15, 2008, 02:46 PM
Infiniti's Avatar
Hmm.. I think I'll be getting the S-Flex, the one that is about 20dB, and has about 40ish CFM. One question though, this morning I took my stock fans that came with my P182 and soldered them together. It worked, but now my question is, what would be a good way of hiding the ugliness of the soldered part? I don't think sleeving would work, so can anyone suggest some good way of hiding it?
  #19 (permalink)
Old July 15, 2008, 02:52 PM
Ah yes you did. Not sure how I missed that....
As for hiding soldering...you did use heatshrink, right? If not, get some on there.... Also, sleeving should work fine. I do it all the time. If you dont want to do that, you can get cable wrap from Radioshack or Home depot and wrap it up.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
  #20 (permalink)
Old July 15, 2008, 09:25 PM
JD JD is offline
I don't exactly find the Tri-Cools all that silent, well if you want some airflow that is. On low they are pretty quiet I suppose but without much CFM.
If you're gunning for silence, replace all your fans with those S-FLEX "E" models and you should be set.
