Old July 13, 2008, 12:24 AM
Default Is this good?
Is this kit good for a noob like me in WC? LOL
what can u advise to change in this kit or addons
Swiftech H20-120 Compact
Gigabyte 3D Galaxy II Liquid Cooling Kit
Swiftech H20-220 Compact
thanks
Old July 13, 2008, 01:08 AM
Cptn Vortex's Avatar
H20-220 Compact is a great starting point. I would not suggest the others.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old July 13, 2008, 05:04 AM
KaptCrunch's Avatar
what are your plans with WC'n ?
single wb or multibles?
Performance: silent / OC'n
Old July 13, 2008, 08:12 AM
well im planing to OC the Q9450 in the future though I only know how to change the FSB freq haha
and only single i only plan to WC the CPU for the time being next time will be the VGAs
and so on
Old July 13, 2008, 10:02 AM
JD JD is offline
Take a look at my build log: http://www.hardwarecanucks.com/forum...ercooling.html However it costs way more than any of those kits you listed due to me using some nice looking things like the reservior and pump top.
Cools my X3350 nicely (5C drop from a TRUE with push/pull P12s). The X3350 is the Xeon version of the Q9450.
With the H2O-220, I believe the fans are rather noisy so you might consider replacing them with Sycthe S-FLEX, Noctua P12 or Yate Loons. The only problem I have with that kit is that your stuck with the CPU block as the pump is integrated into it. If that pump ever dies, you'd loose both parts I'd think.
By parting it out you get a much more customizable setup, however you don't exactly get instructions on how to put it all together but it isn't that difficult if you've read enough forums. If you just want something quick and easy, stick to the Swiftech kits.
Old July 13, 2008, 05:43 PM
Dashock's Avatar
The only thing i could add when buying those kits Blogz is please add Swiftech Chrome barbs instead of the plastic barbs that comes with those kits. The kits are pretty decent.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
