Old July 12, 2008, 06:36 PM
WolfBane's Avatar
Default drain????
If you want to change the water color in your system ,How do you guys drain it ?
Old July 12, 2008, 06:52 PM
Infiniti's Avatar
When I still had my watercooling around, I use to drain it by disconnecting taking the tubing off the pump, but make sure you have a large bowl under it to do it. But if your pump is not at the very bottom of your system (It should be) then you disconnect whatever is at the very bottom.
Old July 12, 2008, 06:57 PM
3.0charlie's Avatar
I always build my loops with enough tubing to remove the res from the case, lowering it to the lowest point possible, opening the fill cap and flipping the res over. Works like a charm.
Old July 12, 2008, 07:08 PM
WolfBane's Avatar
Ok that sounds good but why not add a line with a valve of some type at the lowest point in the loop and use that if you ever needed to drain a system? just wundering?
Old July 12, 2008, 07:09 PM
3.0charlie's Avatar
More leak possibilities.
Old July 12, 2008, 07:37 PM
WolfBane's Avatar
Very true the less componets the less headaches lol
Ok let me ask this how often does one need to redo the water in a wcing system?
Old July 12, 2008, 07:52 PM
3.0charlie's Avatar
The loop? I've stopped counting how many times a long time ago...
Old July 12, 2008, 07:53 PM
Cptn Vortex's Avatar
If you do it right, and dont change parts around, you should be able to leave it for ever.... Just as a rule of thumb you need to top your fluids up every few months or so.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old July 12, 2008, 08:10 PM
WolfBane's Avatar
lol john you change colors alot do you ? lol and paul you say when you ship my system that it is a sealed system?
if so then how do i add ro (distilled) water to the system due to evaporation ?
Also these rezs you guys talk about they arnt sealed huh ? they have a lid i assume?
Old July 12, 2008, 08:15 PM
3.0charlie's Avatar
Change colors? Nah. Change parts? Yes...
A loop is a closed system, sealed in the sense that there are no leaks possible if the hoses are properly connected. Your reservoir: http://www.ncix.com/products/index.p...cture=Swiftech with a top filler point.
