Old July 12, 2008, 08:31 PM
Cptn Vortex's Avatar
Johns got it. I will be using 7/16" tubing on 1/2" barbs, Even TRYING to pull them off and they wont budge....you would need to cut them off....so there is VERY little chance of leaking. Dont worry, I will go over the system with a fine toothed comb....
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old July 12, 2008, 08:35 PM
The easiest way by far i have come across is exactly the way 3.0Charlie mentions.....enough line to be able to bring your res lower than the lowest point of the loop annd outside the box and into a large bowl of some kind.
I also end up changing components alot and therefore it gets drained every 3 months or so because of that.
Having said that a system i put together about 9-10 months ago for someone was displaying higher temps than it used too , i pulled the loop apart , had to strip the cpu/gpu blocks , clean out congealed coolant and other contaminets. I personally think he was topping it up with regular water etc but he swears he was not.....anyways if you have the resources to do it i would change it every 6-8 months or at least flush the system after assembly and use decent additives. It is sometimes surprising to see what comes out of a new rad etc .
Old July 12, 2008, 08:41 PM
WolfBane's Avatar
Ahhh i see now very nice little rez!!! i see it comes with plastic barbs ????? i guess down the road i could add nice chrome barbs????
Also i see what you mean by closed system now the fill port of the rez has a rubber plug wich makes it a closed system:) very nice:)
Old July 12, 2008, 08:44 PM
Dave I'll be using Chrome barbs, save you the trouble.
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old July 12, 2008, 08:48 PM
Be careful with that res tho the lid tends to leak if it is not held upright, the three i have used have anyways.........maybe i have bad luck :P
Old July 12, 2008, 08:57 PM
WolfBane's Avatar
Hey paul thankyou , man this is gonna be a beautiful rig!!!! bling away lol
I have yet to actually in person see a wc rig ,
Man i love tech stuff and mechanics:)
Makes me want to go out and keep adding cc,s to my atv lol arggggggggggggggggg:)
Old July 12, 2008, 09:07 PM
I am happy that you are excited! Like I said, when the parts start to trickle in I'll start a worklog.
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old July 12, 2008, 09:11 PM
WolfBane's Avatar
Again Thankyou Paul and i look forward to the work log:)
  #19 (permalink)
Old July 12, 2008, 09:14 PM
Dashock's Avatar
i would trust Captain he knows wat he is talking about! yea i use a res myself it was leaking at first a little Loose when i didnt hold it upright but a little tightness and now it doesnt leak and i tested it taking this Cosmos S case from the basement to the third floor.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
  #20 (permalink)
Old July 12, 2008, 09:32 PM
WolfBane's Avatar
Hey DaShock good to meet you :) Yea i trust Paul compleatly as well as john(3.0charlie) they have been terrific on answering all my noob ?,s as have all on this forum!
