  #21 (permalink)
Old July 6, 2008, 08:17 PM
Mibs's Avatar
If you're mounting the rad to the back of the case then don't forget the radbox! It seems I overlooked this part.
http://www.ncix.com/products/index.p...cture=Swiftech
I just ordered a whole setup, and now I have to either change my setup plan or come up with some sort of jerry rig to mount the rad on back (I'm too impatient to wait another week for the radbox.)
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
  #22 (permalink)
Old July 6, 2008, 10:58 PM
Dashock's Avatar
Yep used about 6 feet first time second time used the rest of the first time leftover plus a 2 or 3 fett of the new one.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
  #23 (permalink)
Old August 3, 2008, 01:21 AM
EDMCR's Avatar
Now just wondering on a good Loop would Rad-CPU-Res-4870-4870-pump then back to rad be good? or come from the rad go through cpu and 4870s then back to res then pump then back to rad?
  #24 (permalink)
Old August 3, 2008, 02:01 AM
Best loop I can think of is.. pump>res>cpu>4870>4870>rad. Or you could go video card first (after res) and then go to cpu followed by rad. I believe that way you will be giving the coolest liquid..
  #25 (permalink)
Old August 3, 2008, 07:24 AM
3.0charlie's Avatar
It has to be res-pump-rad. Then it doesn't matter much.
Hydro-Quebec is salivating...
