Old July 6, 2008, 03:34 PM
sswilson's Avatar
What case are you planning on installing this into?
Old July 6, 2008, 04:25 PM
Originally Posted by nikitos View Post
the tubing and coolant (or coolant additive(s)) and clamps (not necessary, but they're cheap for peace of mind) :)
just remember to get enough excess tubing in case you have to do the entire loop again. Clamps you can get from a local hardware store, home depot etc. I prefer worm type clamps, cheap and re-usable. Or you can go the zip ties way, either way you will be safe.
Old July 6, 2008, 04:27 PM
hahaha always always buy more tubing than you think you need.
mockups, screwups and under cutting is ALWAYS bound to happen.
Old July 6, 2008, 04:52 PM
sswilson's Avatar
Measure twice, cut once.......... :)
Old July 6, 2008, 05:14 PM
EDMCR's Avatar
its going into Antec 900 Case and for tubing it comes with 10Ft will this be enough or should I get 20 (seems excessive)?
Old July 6, 2008, 05:20 PM
sswilson's Avatar
10 feet is probably what you'll need if everything goes according to plan.
20 feet is what most folks end up needing for their first WC build....
Old July 6, 2008, 06:08 PM
EDMCR's Avatar
hah ok so basically other then the blocks everything I need is there other then tubing clamps? how much feser Fluid do I need?
Old July 6, 2008, 06:14 PM
One 1L bottle should be enough for one fill up, but two will make sure you have enough for refills/top offs.
  #19 (permalink)
Old July 6, 2008, 06:58 PM
CanadaRox's Avatar
On my first build I got 6ft (crazy I know) and I ended up with about 1ft to spare (which I ended up using anyways). My key, measure 5 times, cut 1-2" more than you need, and then keep cutting it down until its right. It worked, but took a lot of time and one mistake would have set me back however long the tubing would take to come + extra shipping.
I'd suggest two bottles of fluid. Even if you don't use all of one (which is likely) there are many things that might happen leading you to need/want more. If you are redoing your loop (adding another block for CF) or you have a leak (knock on wood) or you get a new case or a thousand other things I don't want to list, you'll be happy to have the extra coolant. That is why I just use distilled water. Costs a couple bucks for 4L and I can literally have 4L more with money I find in my couch and a 10 minute bike ride.
Project: Black and White
  #20 (permalink)
Old July 6, 2008, 07:24 PM
sswilson's Avatar
That's how I do it as well.... :)
