  #31 (permalink)
Old July 12, 2008, 10:52 PM
Cptn Vortex's Avatar
Level up: 31% Level up: 31% Level up: 31%
Level: 21 - 834 points to level up
Here is why I would not use an Apogee GTX : XtremeSystems Forums - View Single Post - Help a WC noob, why has my fluid turned yellowish/orange.
Also, I didnt get the desired results from my Feser Dye, so I just got some Feser UV tubing, and needless to say, the effect under UV light is Dramatic. From now on, coloured tubing all the way. Also, less to worry about in your fluid, just distilled water and a few drops of Biocide, and you are good to go.
The Vortex H20
Case....not sure what to call it
DFI X38 LT
Xeon X3210 @ 3.2GHZ 1.30V
PNY 9800GX2 (750/2200)
4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V
Ultra X3 1000W PSU
HT Omega Striker
2x500GB Hitachi RAID 0, 250 Seagate
Sharp 32" Aquos 1080p
Benq W500 1080i Pojector.
Watercooling:
Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro.
Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res.
  #32 (permalink)
Old July 13, 2008, 12:12 AM
MpG's Avatar
MpG MpG is offline
Level up: 44% Level up: 44% Level up: 44%
Level: 15 - 365 points to level up
I'm not sure that's the best example. The guy was running a Striker II, and Asus seems to have switched over to aluminum for their NB Fusion blocks. But there have definitely been a few issues with the GTX block. That, and the cost just doesn't make it a serious consideration these days. Too many other good options for a similar price.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
  #33 (permalink)
Old July 13, 2008, 02:18 PM
thx for the advice. Can you guys please give me a list of everything that i need to buy? The best components and smaller items and tubing. It's for my Cosmos S case. For E8500 cpu , evga 780i FTW and gtx 280 sli or maybe 4870x2 later. I would like to water cool, cpu , chipset and gpu. I have no idea what size tubing i need.
  #34 (permalink)
Old July 28, 2008, 12:19 PM
Default Finished!
After a few weeks of planning and typing, I have finally completed the guide. If their are any mistakes(spelling, grammar, etc.) please inform me. As I will fix them ASAP. Hope you new watercoolers enjoy. Thanks for your support once again.
  #35 (permalink)
Old July 30, 2008, 09:28 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Thread stuck. Make sure you keep it up!!!
  #36 (permalink)
Old August 13, 2008, 10:40 AM
3.0charlie's Avatar
I won't say anything about those subjective comments regarding water-cooling components, but a liquid section (water replacement) is missing.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
  #37 (permalink)
Old August 17, 2008, 10:21 AM
Apollo4g's Avatar
Level up: 69% Level up: 69% Level up: 69%
Level: 13 - 154 points to level up
Nice suggestions in your list, i would not agree with all your criticism, but that natural
Also i see you went into much detail with pricing and such, from experience, those are a pain to update as well as your future products section. It will take alot of time to edit and update. The best thing to do is keep the explanations brief and simple.
Just my 2 cents
I also plan to update or make a new list when i get back to Canada here on HWC.
Mountain Mod Ascension Duality - Sky White
Q6600 @ 3.825 1.45V, D-Tek Fuzion V.2 Waterblock
Gigabyte 4870X2, DD 4870X2 FC WB
Maze 4 NB block
2x Thermochill PA.120.3
2x 2GB Mushkin Redline, 2x 2GB Mushkin Ascent
2x Swiftech 655 pumps
Raptor X 150
3 x 320 Seagate 7200.10,3 x Samsung F1 1TB, 2x 750GB Samsung F1's
X-Fi XtremeMusic
2 x EK Multi option res 250
