Old July 5, 2008, 01:02 PM
sswilson's Avatar
Super Moderator
Originally Posted by miggs78 View Post
I will wait for this guide of yours, seen few of them at other forums but not quite as helpful really.
I think if sswilson and Cpt Vortex also add some info it will be helpful since those 2 are basically in almost all threads in here commenting and helping.
Heh... I'll offer some suggestions if I see anything that comes to mind, but I'm by no means an expert in anything... there are others here on the forums better qualified to comment. :)
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old July 5, 2008, 01:04 PM
sswilson's Avatar
Super Moderator
Originally Posted by Supergrover View Post
How about getting the price added to the items?
Since most newcomers to water wont necessarily know this info.
And I second the full coverage block section.
You should mention that bowing the GT nets you a few more C's.
Best bet for that would be to use a link to the price matching feature. That would keep pricing current.
Old July 5, 2008, 01:27 PM
MpG's Avatar
MpG MpG is offline
Level up: 44% Level up: 44% Level up: 44%
Level: 15 - 365 points to level up
While this has the potential to be an extremely useful thread, I'm not entirely sure what to think about some of the commentary. No component in a watercooling system exists in a vacuum, and just throwing out numbers (i.e. block#1 is one/three/X degrees warmer than block#2) has limited value to someone new to the sport.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old July 5, 2008, 03:35 PM
matsta31's Avatar
Level up: 49% Level up: 49% Level up: 49%
Level: 12 - 209 points to level up
Nice !
full cover block tripled...... just list them as a possibility, since they are by definition good for only one card.
QX9650 @ 4.1 - Fuzion V2 - PA 120.3
DFI - LANPARTY DK P45-T2RS +
2 X 2 Gb Redline
Seagate 320G
BFG GTX280
Q6600 - Asus Maximus - 2 x 1 Gb OCZ Reaper - seagate 1Tb
Old July 5, 2008, 03:49 PM
Dashock's Avatar
Level up: 84% Level up: 84% Level up: 84%
Level: 16 - 120 points to level up
As many have said 7/16 tubing on 1/2 barbs is king but god dam even this time around doing the loop it was a B***h to put the tubing on the pump i even super heated the tubing i had to ask my dad to put it on it took him awhile the metal barbs on the other hand went on like a piece of cake.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old July 5, 2008, 05:43 PM
Default Reply
For the FC Blocks, I don't have performance numbers though. How can I possibly rank them? I'm thinking EK and DD are the only brands in Canada that make FC Blocks.
Old July 5, 2008, 06:00 PM
matsta31's Avatar
ok, then just aknowledge they exist and list their advantage-disdvantage like :
- they do a better job on the card they were created for
- more expensive
- dont work on other card
2 X 2 Gb Redline
Seagate 320G
BFG GTX280
Old July 5, 2008, 06:06 PM
Default Reply
K I'll try... No gurantees though...
  #19 (permalink)
Old July 5, 2008, 06:45 PM
CanadaRox's Avatar
Level up: 31% Level up: 31% Level up: 31%
Level: 10 - 194 points to level up
The FC section is good, but you should make sure you mention that it cools both the actual processor on the card as well as the RAM, VR's and any other chips that require cooling.
X3350 @ 3.6GHz | Asus P5Q-E |2x2GB Dominator @ 1080MHz
VisionTek 4870 @ 825MHz/4.6Ghz|WD 640GB Black
PCP&C 750W Silencer | HT Omega Claro
X3350 @ 4187MHz
  #20 (permalink)
Old July 7, 2008, 08:51 PM
Default Reply
Update: The guides almost good to go. Just a few more sections!
