Old July 4, 2008, 10:09 AM
Synth's Avatar
You have no choice but to use 1/2" tubing if you choose the MCP655.
You have no choice but to use 3/8" tubing if you choose the MCP355.
2 words : aftermarket top. Either XPSC or Petra's
Old July 4, 2008, 10:25 AM
Default Reply
I'd actually replace that 655 with a 355 with PTS Top. Second, tubing. I'd go with 1/2". Don't go Tygon, go with Primoflex LRT, tests(by Mr.Apollo4g and Linus) show that does have a better bending radius than Tygon. Get S-Flex fans from Scythe the F or E series is recommended. Lastly... Plz, plz, plz, plz, plz, plz get the Swiftech MCR320!!! It performs in dead heat with the Thermochill 120.2, price match it and it's alot cheaper. It can be pricematched for about $38! Buy it! I begging you!!!
Old July 4, 2008, 01:03 PM
CanadaRox's Avatar
Again for the MCR320, with D12SL-12's (Yate Loon Sleeve Bearing Low's) the difference between a PA120.3 and a MCR320 is about 1C, and with even lower speed fans (800-1000RPM) it only increases to a 1.5C difference. So unless you've got a huge hole burning in your pocket, or will do damn near anything for that last degree or two, I'd say go with the Swiftech and put that money toward something else.
Here's Martin's comparison of the PA120.3 and MCR320:
(From here: Swiftech MCR320 testing results - XtremeSystems Forums)
Project: Black and White
Old July 4, 2008, 09:05 PM
Dashock's Avatar
True that 3.0 charlie and PLUS One for Noctua Nf-p12s i have 6 of them on the triple rad and their whisper quiet and verrry efficient.
Swiftech Mcr-320 cooling both Gpu and CPu
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old July 5, 2008, 04:26 AM
Mibs's Avatar
Well I'm sorry to admit that I jumped the gun and ordered Thermochill rad...I was at work and got impatient, stupid I know! I did get some Noctuas to go with it. The price on that swiftech rad is killer! The only thing that is keeping me from feeling terribly guilty about my purchase is the fact that I got decent price matches/deals on everything else. Thanks for all the advice guys! At least I know I won't be disappointed with the performance... I'll let you all know how it goes with a log/photos once it all arrives. Thanks again!
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 5, 2008, 06:04 AM
Dashock's Avatar
i hope you got atleast 3 fans if you got 6 even better the Noctua are awesome fans and verrry silent.
Asus P5Q-E
Corsair Cx600M
Old July 5, 2008, 06:34 AM
Supergrover's Avatar
While I agree that the TC only nets you roughly 1c difference, but lets remember it is also a 360 rad not a 240 or 120.2 as TC labels them, so that tends to dull the shine of the 320's.
Still at the price of the swifttech is attractive for the performance but I would like to see how it stacks up to the 120.3 offering that would be a more accurate comparison. IMHO
Still nice loop, I recommend all metal barbs, I dont see the point of having half your loop in plastic and half in metal, plus it looks like crap and the plastic barbs included in the mcres are about 1/2-3/4" longer than the metal barbs so if space or a tight bend is needed that the metal ones are the way to go. Yes I know you got them just wanted to explain why I think they are necessary.
I would also recommend some stainless steel worm-driven clamps, they can be had at your local hardware store for about $0.50-1.00 a piece.
R.I.P.
Old July 5, 2008, 06:47 AM
Mibs's Avatar
Thanks Supergrover, I'm feeling pretty good about my purchase. Like you mentioned the fact that the Thermochill is a 240 will make it a little easier to work with as well. I did pick up those clamps at the hardware store yesterday as well. So the only thing that will be in plastic are the barbs on the pump...I don't know of an aftermarket top for the MCP655, is there one out there?
  #19 (permalink)
Old July 5, 2008, 07:25 AM
ebdoradz's Avatar
if there's one, i havent find it yet
i just ordered a MCP655 too
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
  #20 (permalink)
Old July 5, 2008, 07:34 AM
Synth's Avatar
Careful not to over-tighten the metal clamps, they can cut through your tubing.
And as for the plastic barbs, IMO they offer a tighter seal so no worries
