  #21 (permalink)
Old July 4, 2008, 11:33 AM
Cptn Vortex's Avatar
Check back in a few days, I will have a PA120.2 up for sale.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #22 (permalink)
Old July 4, 2008, 11:40 AM
ebdoradz's Avatar
but if im going external i might get the MCR320 but its there realy a big diff between the 2 rad?
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
  #23 (permalink)
Old July 4, 2008, 09:22 PM
Dashock's Avatar
Ebdoradz i think it all depends on what fans you are going to use im using the Noctua Nf-p12s there was a test done on xtreme forums someone posted it up dam i wish i had a link they did a review of a Swiftech Mcr-320 against the Thermochill rad was difference of 1 degree dam i wish i had the link lookin through the forum for it maybe the poster can post it in here anyways if you have the money get the Thermochill its all up to yea Plus One for the Noctuas cause its quiet and moves a lot of air but again see what deals you can get ive spent wayy tooo much money on WC these 2 months lol.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
  #24 (permalink)
Old July 4, 2008, 10:18 PM
Dashock's Avatar
Here it is CanadaRox posted this Martin Compared both the Thermochill Pa120.3 vs the Swiftech Mcr-320 with different fan setups. Theres like 1-2 degree difference.
Asus P5Q-E
Corsair Cx600M
  #25 (permalink)
Old July 5, 2008, 06:20 AM
ebdoradz's Avatar
the PA120.3 is on same @ 99.99 instead of 143.99 so i will go with the PA120.3 :D
i will have more room for future upgrade :d
  #26 (permalink)
Old July 5, 2008, 06:49 AM
3.0charlie's Avatar
But you will need more space too. Stack up 3 120mm fans on top of each other: that's not even the overall length of a triple rad... those suckers are huge.
Hydro-Quebec is salivating...
  #27 (permalink)
Old July 5, 2008, 06:53 AM
ebdoradz's Avatar
ok since they were good special on the sponsor sales ive finaly jump into it
Masterkleer Pvc Tubing 7/16IN ID 5/9IN OD 10 Feet
Swiftech MCB-120 Radbox Revision 2 Black Thermochill Pa 120.3 Triple 120MM Fan Water Cooling Radiator *No Barbs*
Ek Water Blocks 1/2IN G3/8 Chrome High Flow Barb Fitting (Single) for Thermochill Radiators
D-TEK Customs Fuzion V2 CPU Water Block S478/LGA775/S939/AM2/S754 1/2IN Barbs
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
Thermochill Mounting Screws 1-1/4IN for Closed Corner Fans (4 Pack)
Feser One Feser View Yellow UV Reactive Dye Water Additive 50ML Bottle
Silverstone 120MM FM121 Case Fan White 800-2500RPM 17-39.5DBA MAX. 110CFM
D-TEK Customs 1/2IN G1/4 Chrome High Flow Barb Fittings (Pair)
all i need is a GPU block i will start my build when those part will arrive and by then i will order what i've been missing to complete thta build
im hopping temp that will be much lower then my air temp with this high end watercooling gear
  #28 (permalink)
Old July 5, 2008, 06:55 AM
Supergrover's Avatar
This is another instance where a cardboard mock up is helpful, when ever space is a concern simply grab the specs from the manufacturer and whip up a mock-up out of cardboard, nothing worse than purchasing a product only to find it wont fit where you wanted it by 2-3mm. Sometimes you can mod things to fit but sometimes not so much.
R.I.P.
  #29 (permalink)
Old July 5, 2008, 03:42 PM
Dashock's Avatar
I use the Swiftech Mcw-60 its a pretty good gpu block on my 8800gt i been stressing it with Gpu caps viewer highest temps i got so far was 35.
Asus P5Q-E
Corsair Cx600M
  #30 (permalink)
Old July 6, 2008, 06:48 AM
ebdoradz's Avatar
thats what i was gonna get but it was out of stock ... :S
