Old July 3, 2008, 07:30 AM
zlojack's Avatar
Dual loop. It's actually pretty crowded in there and I'm not sure if I did the best on routing the tubing, but here's my worklog. The pics starting on page 8 until the end show how I fit it all in. I actually have changed it slightly because I sold one of my 3870 X2's with block, but that should give you an idea.
Old July 3, 2008, 08:02 AM
Eldonko's Avatar
Hardware Canucks Reviewer
I recommend Eheim 1250 if you want power and durability. I have run mine 24/7 for 3 years and it has power enough to go through 3 water blocks and 2 big heatercores in a very big loop no problem. It is a little bigger than most but worth it IMO.
I also agree with using reservoirs, it is easier to bleed and deal with in general.
Old July 4, 2008, 06:13 AM
ebdoradz's Avatar
ok
thank you for all your tips and recommendation
i might consider a reservoir, but im still thinking about the rad . 240 internal or 360 external??
if im on a 300$ budget which one, and which part you recommend me?
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old July 4, 2008, 07:02 AM
Dashock's Avatar
Lowfats got it right the Mcr-320 kicks ass as well the swiftech Res took me forever on my first loop to bleed all the bubbles from the intergrated rad/res of the swiftech Mcr-220 anyways the Mcw-60 is also an awesome block too.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old July 4, 2008, 07:13 AM
Jack Rabbit's Avatar
What about temporarily putting in a reservoir? You could probably jury rig something out of a couple quick connect fittings. That fill port reservoir does not look like it would actually help speed bleeding because the fluid would not be flowing through it.
- James Graham
Old July 4, 2008, 09:03 AM
ebdoradz's Avatar
ok the MCR 320 seem like a good option but if its performing almost the same has the PA120.2 or the Feser 240, it take less space, you need 3 fan instead of 2 and it cant be mount internel without serius mod to my case
whats your opinion about this?
pa120.2 external - i need a rad box + 2 fan
pa12.2 internal - already have the fan in front of my case
mcr320 external - need radbox + 3 fan
Old July 4, 2008, 09:38 AM
zlojack's Avatar
Well, if you're just cooling the CPU and one GPU, the 120.2 should be fine. My suggestion is to mount it in the front drivebays with the air blowing out of the case (so as not to dump the heat into the case).
Old July 4, 2008, 09:43 AM
ebdoradz's Avatar
yeah but that will screw my current case airflow. since it was design to flow from the front to the rear.
maybe a PA120.2 external could fit it too. im a bit confuse about the mounting of this rad
i have already see @ diy-street.com alot of water cooled stacker with rad in front and fan pushing air into the case.
  #19 (permalink)
Old July 4, 2008, 10:54 AM
Default Reply
Get an MCR320 hands-down... It performs the same if not better than the Thermochill 120.2. Also for GPU block wait for the D-Tek FuZion GFX V2. Better performance, yet lower restriction. Impressive.
  #20 (permalink)
Old July 4, 2008, 11:20 AM
zlojack's Avatar
Of course the 320 beats the 120.2, but it won't fit inside his case.
