Old July 2, 2008, 08:19 AM
Synth's Avatar
Default Cosmos watercooling question - top-mounted rad...
This is for all you watercooled Cosmos users with top-mounted rads :
Are your fans setup as intakes (drawing air inside the case) or exhausts (exhausting hot air through the rad) ?
I'm happy with my NF-P12 setup as intakes (pulling cool air through the rad, from the outside), but I've never really tried the other way around...
Hell, anybody tried both and could share the results?
Old July 2, 2008, 08:36 AM
sswilson's Avatar
Mine is set up to exhaust out of the case.
I figured with that much airflow (6X 1350 yate loons on the rad, 1 exhaust on the rear, fresh air only for the PSU, and intakes both front and bottom front) that there wouldn't be much chance for heat to build up in the case anywise.
Old July 2, 2008, 12:47 PM
werty316's Avatar
Setup them up as exhaust fans.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old July 3, 2008, 03:20 PM
Though I don't have it built yet, mine will be exhaust. This is mainly for dust prevention as the air inside the case will be filtered air.
Old July 3, 2008, 11:07 PM
Dashock's Avatar
I just finished installing my loop their setup push/pull but exhausting air from inside the case to outside.
Those are idle temps which i think its pretty nice im gonna have the load ones soon.
And here is stressed i didnt find much difference between the Everest stress test and prime im working on some more mhz outta my gpu. Maybe someone can tell me when im looking at AMD temps do i look at the cpu temp or the core temps?
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old July 4, 2008, 06:33 AM
ebdoradz's Avatar
33°C full load that some serous cooling buddy
still running it @ 2.65???
does your temp increase alot if your making that 8800GT running full load. im curious to see how much heat a video card like those put in the loop. and if it will increase the cpu temp by alot?
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old July 4, 2008, 06:55 AM
Dashock's Avatar
oh nono ebdoradz this is stock volts stock everything the videocard is clocked slightly but nothing serious im just doin sum stability tests i ran prime too so the temps match Everest trying to see how far i can clock my videocard. Im using vista at the moment and for some reason Ati tool refuses to work with me.
And P.s im not sure if i should be looking at the 33 as my temp or the individual core temps as my temp.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Old July 19, 2008, 11:45 AM
Fans should suck air through the rad and not blow. You get less turbulence and better airflow that way.
That said. The fans should suck cool air from outside and into your case. The trick is to make sure that your front and rear mounted fans create a strong enough air current to blow the rising hot air out the back so that the cool air coming in from the top is not fighting against it and just merges into the air current.
This will likely suck in more dust but but no matter how you slice it, dust gets in no matter which way the air blows. You just have to deal with it.
Sucking or blowing hot air from the case through the rad makes no sense to me whatsoever.
Old July 19, 2008, 12:03 PM
sswilson's Avatar
Sorry but I have to disagree. (Not about the "sucking" part, but we're talking about push/pull setups anywise).
Since the hot air rises inside the case, drawing in from the top is going to blow all of the hot air from your cooling loop back over the CPU & motherboard components which is completely opposite to what we want.
With a single CPU loop and a rear exhausting video card (or WC cooled Vid card) the great majority of heat which is normally generated inside a case is already being transfered to the rad, thus you want that heat exhausted out of the case rather than back into it.
