  #31 (permalink)
Old July 2, 2008, 12:53 PM
Another elbow? Not necessarely. Check this out. I don't see why it would not work.
that did cross my mind but I wasnt sure how the hose would be getting it on the fitting... but I did think of that.... :)..
GOOD NEWS... kit showed up today at work... man I gotta tell ya its hard finishing the rest of the day out when @ 10 am Purolator show up with the goods..... makes for a long day!!!!
now I just need to work the nerve to buy the GPU blocks... those are a 3 week waiting period...
Anyone ever buy straight from Koolance before?
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
  #32 (permalink)
Old July 2, 2008, 01:57 PM
3.0charlie's Avatar
Patience, my Young apprentice. Patience... ROFL
Did you give shoprbc.com a call, about the Koolance parts availability? They're located in Nepean (next to Ottawa); been a few times from Montreal, to buy my Koolance parts. They just may have the blocks faster.
I've never dealt with Koolance directly.
Hydro-Quebec is salivating...
  #33 (permalink)
Old July 2, 2008, 05:34 PM
I have not a clue how im gonna mount that rad up inside the case under the fan. I took the fan grills off and it sits pretty good, but holding it up there is gonna be a whole other ball game.... Two -way tape??
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
  #34 (permalink)
Old July 2, 2008, 05:47 PM
3.0charlie's Avatar
That's a 200mm fan, right? You'll have to create a shoud to structurally attach the fan to the rad. And then add support brackets for the other end of the rad.
One aspect of water-cooling is to be creative. And double-sided tape is not a good idea.
  #35 (permalink)
Old July 2, 2008, 06:26 PM
Haha!! very true, I've used it enough times, it works like charms..
  #36 (permalink)
Old July 3, 2008, 06:54 AM
this isn't good news...LOL.... i failed art class, but Ill do my best!!!!
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
  #37 (permalink)
Old July 3, 2008, 04:50 PM
I ripped the top of the case off tonight and tried to fend my 2yr old off in the process.... I can mount the rad to the case using the screw holes in the rad, but Ill need to drill some clearnace holes in the case. The only PROBLEM i can see is the end of the rad being to close to the reservoir if i put it on the top bay. im gonna have to spend some time and rearrange everyting... move the hard drives down, remove the HD fan and see whats what.....
What I will do is rip off the top again next week (the kids and momma are on vacation eleswheres) and fire the rad in, and put the res in and take some photos for you too see......
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
  #38 (permalink)
Old July 4, 2008, 03:42 PM
OKay,,, since I cant really do anything until I get the GPU blocks..... I think I am going to try and get the rad installed and pump, and figure out where everyhting is gonna go.
I had some spare time so I think I have my fittings all ready to go... I have some 90 degrees if I need them, and also 2 quick disconnects for the fill tube and drain...
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
  #39 (permalink)
Old July 4, 2008, 04:01 PM
3.0charlie's Avatar
Yup, good thing to start the lay-out physically.
You bought which GPU blocks?
  #40 (permalink)
Old July 4, 2008, 05:21 PM
KaptCrunch's Avatar
depends where using 5 elbow's will hurt the flow
