Old June 25, 2008, 03:57 PM
Default Adding a second duall rad to the h20 220 compact?
Would anyone know if adding a second dual rad to the H20 220 compact kit would do any harm or hinder the performance of the apogee drive pump? Would the pump be able to push the fluid through the loop at ease?
thanks... any thoughts welcome..
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old June 25, 2008, 04:11 PM
MpG's Avatar
MpG MpG is offline
Go right ahead. The Apogee Drive is actually just a modified MCP350 pump that's used by lots of watercoolers, so it won't mind an extra radiator.
Old June 25, 2008, 04:35 PM
could I use a normal rad or would I need a rad/res combo like the H20 220 kit??
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old June 25, 2008, 05:50 PM
Dashock's Avatar
You can use a normal rad it is fine i think your kit came with a rad/res combo.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old July 5, 2008, 07:46 PM
Good to go, my 350 pump is pushing 3 120 rads, a bay res, apogee GT cpu block, and 2 koolance 8800 GTX blocks.
Way better cooling from 1 to 2 rads, about another 25% moving to the 3 rads.
Q9450 @ 3.4 is mid 30's idle and upper 40's at load, gpu's are 50c idle and 58c load.
Old July 6, 2008, 05:41 AM
Can you please tell me how you like the Koolance 8800 blocks?? I just ordered them and am currently waiting there arival. How do they work, how do they look, how was installation??? Did you buy the slot extension tube that kits inbetween the two cards (hooks them direct)?? I would love to see some photos of them.... could always email them to me or Pm....
I'd appreciate it!!!!
thanks...
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old July 6, 2008, 05:46 AM
sswilson's Avatar
thanks...
Hey!!!! what's with the request for an exclusive view!?!?!?! (We all want to see.... :) ).
VBImage host (up top) is your friend..... :)
Old July 6, 2008, 11:30 AM
LOL...... That Vbimage thiing is pretty cool... I had no idea!!!
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
